Battery light
Battery light
I have an '86 Toyota pickup (22R). The battery light came on so I did the basics, checked connections and had the alternator checked. Turns out the alternator was going so I replaced it. However, the battery light is still on. Connections are good and clean, belt is tight, wires are in good shape. Any suggestions?
I don't have a wiring diagram for your truck but I suspect the ALT fuse or fusible link is blown. Disconnect the battery and check for continuity between the alternator and the fuse box. If that's good, there may be a problem in one of the alternator wires. You will need a wiring diagram to identify the wires and their routing.
I got a defective alternator at napa. It lasted me from Roseburg Or. to Browns Camp were it died. I returned it to napa and this one has lasted me 2yrs so far.
Did you have the old alternator checked to see if it was bad?
Yota.Jay
28
Oct 22, 2015 01:08 PM
FS[PacNorWest]: Toyota Inclinometer/Altimeter
AkitaDog
Sep 1, 2015 08:05 AM
Sandman
Jul 14, 2015 12:36 PM
