General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
A/C turning on when car starts
Old Nov 19, 2009 | 01:27 PM
BUZY's Avatar
I have an annoying problem. My A/C turns on automatically when i start my car and i have to push the off button multiple times, sometimes really hard, to turn it off. But when i'm driving or when the car is on for 30min or more the control panel works fine. Could this be wiring problem or machanical where i need to replace the entire thing?
Old Nov 19, 2009 | 01:39 PM
Elton's Avatar
does yours have the digital HVAC controls ? its not set to auto is it ?
Old Nov 19, 2009 | 02:42 PM
BUZY's Avatar
it is digital and no its not on auto. the problem is that it comes on automatically when i start the car even when its off before i turn off the car, or sometimes while the car is running it just comes on by itself.
Old Nov 19, 2009 | 02:55 PM
Thelast83inNJ's Avatar
What kind of car? year?
Old Nov 19, 2009 | 03:02 PM
Elton's Avatar
ehh My ride: 2000 4Runner
Old Nov 19, 2009 | 03:38 PM
I would think it's the climate control head, since you said everything works normally after a while. There is no mechanical linkage or connection to the heater/ac units from the controls. Everything is moved by electric motors. The head is just a keyboard. The A/C Heater amplifier just runs the blower speeds?? Probably an expensive guess, any friends let you try theirs?
Old Nov 19, 2009 | 04:25 PM
Elton's Avatar
a/c relay ?
Old Nov 20, 2009 | 06:41 AM
BUZY's Avatar
yeah, that's gonna be an expansive fix, i hope after i screw around with it a bit it'll be better, it's not like it can't get any worse...maybe...
Old Nov 20, 2009 | 07:06 AM
GSGALLANT's Avatar
Is your airflow direction selector set to blow air at the windshield? Mine automatically cycles the A/C compressor on/off when any windshield defrost flow direction is selected (either just windshield, or windshield and feet). The reason it does it is to knock some of the moisture out of the air before blasting it at the windshield (moist air on cold glass will cause it to frost.)
For your digital system, it might be based on either the interior or exterior temperature, or it might do it automatically for a set period of time after you start the truck.
As a test, see if it does it if you move the airflow direction down to just towards feet.
Old Nov 20, 2009 | 11:05 AM
BUZY's Avatar
the thing is though, I'm having trouble changing the setting too. I have to press the buttons repeadedly, sometimes really hard, and then it changes but as soon as i let the button go, it goes right back to whatever the setting it was.
aciorba23
Jun 29, 2015 04:18 PM
WI Girl
Jun 25, 2015 03:45 AM
94hiluxZE
Jun 22, 2015 10:42 AM
Lowviz
Jul 4, 2002 09:43 PM
Toyota Punk
Jul 1, 2002 05:44 PM
