CEL and VSC lights on !
I got a pocket code reader and this is what I have line by line......
P300
P303
Mil On
Monitrs
2 Inc
Catalyst
Evap
5 Ready
Misfires
Fuel
Comp
02 Sensr
02 Htr
I think one of my coil packs or power packs (whatever they are called) are going as the truck runs like crap when cold. If I have to guess it would be the pack closest to the firewall. I have a spare packs and will replace all 3 tomorrow, I also have another 02 sensor assuming they are the same for the front on a 02 Tacoma. The rear O2 sensor might be going but it could also be the cat, I have a URD O2 sim on that so the #'s down stream are fixed. I assume if a coil pack was bad the mix could be wrong and then set the front O2 off, but gimme a hand please.
A
P300
P303
Mil On
Monitrs
2 Inc
Catalyst
Evap
5 Ready
Misfires
Fuel
Comp
02 Sensr
02 Htr
A
PO300 is ramdon misfire. PO303 is cyl#3. P304 is cyl#4 etc etc. Plugs first, wires second or put your timing light on each wire it and see it flash tells you wire and/or coil pack ok. Cat efficiency code is P0420,most time cat is bad not O2. Your ready monitors say that all have run ok including heated o2s
Awesome info had I read my manual that came with the code reader it might have told me that. I bought new plugs, wires and I Have some pre-owned coil packs. Will transfer tonight..............
A
A
FS[PacNorWest]: Toyota Inclinometer/Altimeter
AkitaDog
Sep 1, 2015 08:05 AM
Sandman
Jul 14, 2015 12:36 PM
