swapped 882 for TRDs. Rear end Alignment ?
Old Nov 9, 2009 | 09:54 PM
E30RUNNER's Avatar
I was able to bring my rig down about an inch. The 882 were too high for my taste probably because I didn't have any serious weight in the front.
driver's side before
passenger side before
I was right at 40" from ground to center wheel well running 285/75/16 mtr
TRD's
I am now at 39" running a stock front and both measurements were with OME N86SC struts. Ride is great a little firmer than with the 882 but nonetheless rides great with the comfort OME shocks. I will post some pics up tomorrow of it. I will be finishing my swap this weekend when I install the LC coils I have sitting in the garage.
Alignment, please help me out with this. I took it to NTB and this is the read out they gave me...
Do these numbers look right to you? the rear feels a little squirly but not too bad. I just wanted to know if this is about the same read outs others are getting?
Old Nov 9, 2009 | 10:02 PM
j-money$$$'s Avatar
i didnt think there are any adjustments in the rear for alignments.
Old Nov 9, 2009 | 10:31 PM
02_Limited's Avatar
It looks like they have the machine set to Rav4 mode and not 4Runner mode - maybe that has something to do with the squirrelly feeling in the back suspension? Incorrect parameters for the camber, caster, etc. will definitely have a negative effect on handling. Make sure that the "specified ranges" are correct
Old Nov 9, 2009 | 10:44 PM
kinzer's Avatar
the set vehicle doesnt mean jack if you know what your doing, all it does is tell you if your within factory specs for that vehicle. your camber looks great, caster is fairly decent, your toe is a little too negative for my tastes, i prefer .05 at least, i usually set to .10 degrees. the problem i see is your rear thrust angle is way off, looks like the left side is kicked back which would theoretically only cause the truck to cat walk sideways down the road.
Old Nov 10, 2009 | 06:31 AM
E30RUNNER's Avatar
Could this be caused by the panhard bar being over-extended?
I was thinking about it and when I first put my lift on a friend cut my panhard bar and welded a sleeve to it. Since then my suspension has settled 3/4 to 1 in. Could this cause problems with the thrust angle?
Old Nov 10, 2009 | 07:13 AM
clydehatchet's Avatar
if you were getting your rav 4 lined then the rear is still in bad shape. take it back to ntb and have them do an alignment to your 4runner, unless you prefer the rav 4 specs.
Old Nov 10, 2009 | 07:36 AM
E30RUNNER's Avatar
It's going back today.
Old Nov 10, 2009 | 08:47 AM
desertcamper67's Avatar
You can push the rear housing around some with the u-bolts loose. We use a port-a-power with good results. The center pin within the spring pack is a little smaller than the hole in the spring perch so you can push the right side back, remeasure and then push the left side forward if needed.
Old Nov 10, 2009 | 08:54 AM
Elton's Avatar
lol 3rd gens dont got u bolts there all coils have you checked the axle to see if its centered might have to get a adjustable panhard bar
Old Nov 10, 2009 | 08:56 AM
My bad. I forget about the evolution of these truck sometimes.
In this case look at your links/trailing arms. One might be bent.
Old Nov 10, 2009 | 08:59 AM
Elton's Avatar
they should of kept the leafs
Old Nov 10, 2009 | 09:20 AM
brian2sun's Avatar
That shop should not have charged you extra to align the rear as there are no adjustments to be made. They usually won't tell you that and just get you for another $30. If they did, demand a refund! The only adjustment that can be made is to install an adjustable pan hard bar (like the others mentioned above).
I don't see how they got before and after measurements on the rear. That printout looks like BS to me.
Old Nov 10, 2009 | 09:23 AM
brian2sun's Avatar
And yeah, he's got you listed as a Rav4 with tiny little pizza cutter tires - not 33s.
Old Nov 10, 2009 | 09:31 AM
Agreed. Since the cargo is usually people now with soccer Mom's and all, it seems softer is better.
Those rear readings don't surpise me. The slight difference between before and after are so slight that the readings were probably right on the bubble. The machine may do some rounding off too.
You definately shouldn't be charged for a 4 wheel alignment. A thrust angle alignment may be sold to ensure a straight steering wheel though. But a slightly off steering wheel doesn't wear tires and isn't actually out of alignment. Just cosmetic.
Old Nov 10, 2009 | 09:48 AM
E30RUNNER's Avatar
I thought I could avoid having to spend the $ on the panhard but I think it's next on the list of things to get...
My total cost for the alignment was $50 bucks and some change.
Old Nov 10, 2009 | 09:54 AM
Elton's Avatar
measure the width on both sides and see what it is
E30RUNNER's Avatar
Would you check it by seeing how much each wheel sticks out on either end?
Old Nov 10, 2009 | 10:02 AM
Elton's Avatar
with my tires from touching the the frame from where the swaybar end links are to the end of the tire lugs are is roughly 13.5'' thats how i checked mine
Old Nov 10, 2009 | 12:15 PM
ESQ's Avatar
ESQ
Wow, Jesus worked on your truck. Blessed is your suspension.
Old Nov 10, 2009 | 01:41 PM
E30RUNNER's Avatar
I feel better already!
here's the second read out for today's alignment
