MY new 1995 4runner
Old Nov 5, 2009 | 04:37 PM
maui454's Avatar
MY new 1995 4runner
Well I bought this today for 2500.00 I am stoked. It has a 5sp 6cyl 4x4 141000 miles and runs really good. I am happy. What are some preventive maintenance I should do to it? and is there anything I should look over that I couldn't do on the test drive?
Attached Thumbnails MY new 1995 4runner-1105091528.jpg   MY new 1995 4runner-1105091528b.jpg
Old Nov 5, 2009 | 05:26 PM
abecedarian's Avatar
at 141K miles, the timing chain (unless it's been changed recently) will need replaced as will the guides for it. I recommend finding steel backed guides for it but if you change the chain at approximately 80-100K mile intervals, the stock guides should work fine.
Also, you might want to have the front CV boots and joints looked at as well as all of the u-joints.
From the pics, it looks like the rear springs have fatigued a bit so you may also consider replacing those.
Beyond that, typical servicing of the differentials, gear box, etc. would be a good idea as well.
Old Nov 5, 2009 | 05:31 PM
90-3vzeslug's Avatar
def check the core support to see if the timing belt has been done. if nothing written about it i would recommend having it changed. the v6 is NOT an interference engine so it wont necesarily get trashed if the belt goes, but it's a good idea to avoid it.
only the 22re 4cyl motors have timing chains.
fluids tune-up the usual for the rest.
Old Nov 5, 2009 | 07:27 PM
maui454's Avatar
Hey thanks guys. One quick question I went and did some minor wheeling tonight and when turning around my rear end was acting like it had a locker? Was that a factory option in 95?
Old Nov 5, 2009 | 07:49 PM
jays92's Avatar
my 92 does the same thing i dont think it was a option in 92
Old Nov 5, 2009 | 08:00 PM
camo31_10.50's Avatar
nope....
my '86 pickup acts like it has a locker in the rear if i make a sharp turn in 4lo...it kinda jumps a little..
but i'm 100% sure that a locker wasnt available until like 96 or somethin like that..whenever the 3rd gen 4runner came into the market..
Old Nov 5, 2009 | 08:03 PM
CRafferty's Avatar
siii. no factory lockers till 96.
or 95.5 if those early taco's had them..
Old Nov 5, 2009 | 08:04 PM
jays92's Avatar
its always does it in 2wd camo, when i make a sharp turn backing in my driveway to go the other way, i know its not a full on locked rear but maybe a limited slip will do this?
Old Nov 5, 2009 | 08:32 PM
olharleyman's Avatar
Flush the radiator & engine ,DENSO plugs,oil filter & oil, FACTORY wires, cap and rotor, clutch and brake fluid, timing belt water pump and pulley's,trans transfer and rears fluid,rear coil springs all so you know they are done and it will keep the 3.0 running well and reliable for another 100+ thousand miles.
Old Nov 6, 2009 | 01:09 AM
Matt90V6SR5's Avatar
Is it wrecked on the drivers side? or is that shadows I see
Old Nov 6, 2009 | 01:25 AM
toyota4x4907's Avatar
Hey! I paid 2500 for mine as well!! Nice lookin runner, man.
Old Nov 6, 2009 | 03:06 AM
crawyota's Avatar
From: CHESTER COUNTY , PA ; by way of KOBLENZ , GERMANY
hey i got a 95 4 runner sr5 , that i got a few years ago for like 5.000. i have changed a bunch of things on it , i lucked out and got factory installed 4.88 gears. but it does look like you got the rear sag issues def. change all the fluids. and such. don't look to do to much to the motor performance wise since the 3.0 sucks to begin with. i do love it though , it is great on the trails. i'd ditch the running boards and mud flaps
smthwsn357
May 1, 2024 07:28 AM
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
mskalmus
May 28, 2017 07:51 AM
BeMiceElf
Oct 10, 2015 09:40 PM
