where do these vacuum lines go
87 22r carb. I am thinking maybe the char cans? can't seem to find them anywhere in the fsm, autozone vac dias etc. thanks. I think #2 goes to the air cleaner.
1: Outer Vent Control Valve -- to charcoal canister.
2: to mixture control valve on underside of air cleaner. (Did you mean to circle the port to the right?)
3 (?): to thermo valve and mixture control valve (t'd) underside of air cleaner
the larger hose on the right of #2 is for the MC valve. so that still leaves #3 open, however i do have 2 char cans front and rear. which one does the #1 go to? maybe #3 goes to the other one? #3 comes directly off of the intake manifold. and yes #2 is the smaller port, I confirmed that also goes to the MC valve.
TokyoD23
Jul 12, 2015 06:01 AM
