How to tell if your engine is frozen
Old Oct 18, 2009 | 09:53 PM
RDKUT's Avatar
How can you tell if you've frozen your pistons? (89 Pickup 22RE)
I've searched the forum but haven't come across anything explaining how to check if you froze your engine..
Why do I ask?
Driving home on the freeway my car stopped accelerating. The engine was off, the brake, oil, gas lights all turned on) I pulled to the shoulder.. Tried starting it back up, it started twice and died after about 5 seconds each time.. Towed it home..
I checked the oil dipstick.. had no reading.. So I'm afraid I killed my engine..
In the months leading up I never saw the oil light come on, so there was no indication I was out.. I refilled with 4 quarts of oil, hooked it up to the battery on my buddys Tundra and now it only turns and turns but doesn't start..
Think its frozen? Or think it might be something else?
Old Oct 18, 2009 | 09:58 PM
Elton's Avatar
turn the crank pulley bolt see what happens
Old Oct 18, 2009 | 10:16 PM
Jay351's Avatar
Turn the main crank bolt with a rachet. IT should rotate with general ease in the clockwise direction..
Check the AFM. Look up the toyota 93 FSM in the FSM sticky..
Old Oct 18, 2009 | 10:22 PM
peow130's Avatar
Do a compression test.
High-Heat will destroy cylinder walls.
Old Oct 18, 2009 | 10:24 PM
VSU_4runnin's Avatar
check it with a thermometer?
Old Oct 18, 2009 | 10:32 PM
turboboost's Avatar
If it's turning over, it means that you haven't seized the motor...
Old Oct 18, 2009 | 10:36 PM
peow130's Avatar
High Heat = More friction...
and from what i know about engines, more friction = gouged up cylinder walls..
And gouged up cylinder walls are bad, mkay.
Old Oct 18, 2009 | 10:46 PM
RDKUT's Avatar
thanks ill check those things out.. I should also mention the thermostat never went passed halfway.. surprising seeing as how it was out of oil!
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
jasonty
41
Dec 23, 2018 01:00 PM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
