Truck not idling, but good power.
Old Oct 16, 2009 | 05:14 PM
leaffybugg's Avatar
I just purchased a 94 Pickup, it runs great, lots of power when going trough the gears and on the accelerator. It just hesitates when starting and idling other than that, no problem, i have put new spark plugs, and wires and checked the cap. Any help would be great.
Old Oct 16, 2009 | 05:16 PM
iamsuperbleeder's Avatar
what motor?
do you have a tachometer? what's the idle RPM's at?
Welcome to YT btw!
haha, did you pull your user name from that movie "I Spy"? lmao, that movie's great...
Old Oct 16, 2009 | 05:26 PM
leaffybugg's Avatar
Thanks, its a 22RE, i have no tachometer, it only seems to do it in low RPS. when the engine is cold and the idle is up i dont feel it as much, but once its up to temp, it hesitates when idling.
Old Oct 16, 2009 | 05:29 PM
hmmm...
you MAY just need to turn your idle up a bit...
but it could also be a different underlying problem...
check engine light on? have you tried to see if any codes are stored in the computer?
Old Oct 16, 2009 | 09:21 PM
leaffybugg's Avatar
no check engine light on, i put Lucas fuel system cleaner in it and out of the blue it started running 10 times better. I had a buddy look at it, it ran perfect when he was checking it. he noticed the throttle cable was a little loose, so i will adjust it tomorrow. he also suggested fuel filer. i forgot to mention before when it was hesitating, i could smell gas as if it was running rich. but tat smell just almost went away completely today when it started running better. maybe bad gas? deposits? im going to change the fuel filter tomorrow. let me know if you guys think of anything else.
thanks
JF9243176
Oct 8, 2017 04:21 AM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
slider417
Jun 22, 2015 10:18 AM
nyk08trx
Jun 18, 2015 09:01 PM
XtremeOff-Road
16
Jun 27, 2002 07:32 PM
