22RE intake install
22RE intake install
So here's where I'm at on this 22RE. I am about to put the lower intake manifold on, but the gasket I got with my kit covers that coolant port at the back of head as well. Should I be bolting them up at the same time, or can I cut the gasket between them to seperate it into 2 gaskets, and bolt up the collant hard line after I get the intake in place?
Here's some pics-
Here's the head
Here's the coolant passage at the back end
My gasket covers both the intake ports and the coolant passage... so how should the install go?
Also here's a pic of my EGR plate, and the 2 hard lines that I have
Can you identify these 2 lines, and which goes where? Also, if one of both of them are bolted into the head at the EGR plate, which hole does that bolt go through?
I basically need to know the best way to hook all this stuff up. Thanks!
Here's some pics-
Here's the head
Well I put my intake on in the truck...after I had the head installed so I put all mine together at once. I would not cut the gasket, but that's me.
As for the 2 pipes the all metal one goes to the EGR and the exhaust manifold. As for the other the metal part goes to the underside of the intake (I believe in the middle of the lower intake) and the rubber end goes somewhere around the heater valve.
I think the all metal is on top of the other.
It's been a while since I had a good look at these.
I believe the chrome one is a coolant pipe. The other I know is part of the Air Injection System. One end connects to the PAIR valve under the intake mani and the other end connects to the tube attached to the top of the exhaust manifold. It is NOT part of the EGR like most people think.
Thanks for the help guys, I got the lines straightened out. But as for the lower intake gasket... If you would not seperate the intake ports section from the coolant passage, then how is the install done?
The hole you're pointing at is where the EGR bolts on. It's exhaust gas, not coolant.
Mine is carbed, so I'm not sure what you're dealing with. I haven't put mine back together yet, but the side cover (has a valve screwed in top) goes on first, then the intake, then the EGR valve w/tube.
My question is, since the intake manifold incorporates that EGR passage, should I be installing both of them on the head at the same time? Or can I carefully cut the gasket to seperate them, and install them at seperate times... propably not much reason too, though?
Also, I need to know what all should be on the block on both sides. I am referring to the sensors and bolts, not accessories.
Here's the passenger side, I've got the knock sensor to the left of the oil filter, and the pressure sensor under the filter-
Here's the driver side, I have only a bolt that I am pointing out(I believe it is the block drain)-
Here is the driver side with its coolant hard line mocked up, is this something I should have in place before I drop the motor in, or will it be easier without?-
Off the subject, but what kinda mileage could I expect with a fresh motor, balanced, and a 260 grind on the cam, 31'' tires?
I bought this '94 extra cab with a real bad head gasket, but driveable. I had the motor completely rebuilt, and when its all done, I'll be into it for around $2800. Not bad.
with the specs you read in my sig, I'm getting just a hair over 18mpg after recently replacing a bad O2 sensor
not bad if you ask me
driving style has a LOT to do with it though, ESPECIALLY on a non-stock motor. You can stay at original MPG all day long with a built motor if you drive civil, but the second you lay into the throttle and USE that extra HP, you can almost watch your gas gauge needle drop, lol
Also make sure you install the big "U"-shaped coolant line that runs from the water pump to the bottom of the radiator.
steve miller
Oct 10, 2015 01:40 AM
Sep 4, 2015 09:27 AM
