another "wont start" thread
Old Oct 3, 2009 | 04:47 PM
GavinWhite's Avatar
I have a 2000 4Runner Limited and for months everything has been working fine. The starter was replaced a few months ago, and the car has since been working perfectly until just a while ago when it simply would not turn on
The 4 wheel drive indicator is blinking on the dashboard, but I havent used that feature in months, which i found odd.
The battery is fine, the starter is new, and I seriously dont know what to do. Ive been researching the problem and have yet to come up with any results to fix it, so ill be more than happy if anyone could help point me in the right direction to fix it
Old Oct 3, 2009 | 05:11 PM
nc994run's Avatar
From: raleigh, nc for school chapel hill, nc for home
Check your starter contacts and fuses
Old Oct 3, 2009 | 05:36 PM
1990yota-pickup's Avatar
use a pair of jumper cables from the negative off the battery to the frame.. could be a simple grounding problem.. Inspect all the main grounds and postive hot wire to the starter. if you have any green color wire cut it out the corrisoin or just go buy some new cables at the part store.. should be less then 40 bucks out the door.
Old Oct 4, 2009 | 08:38 AM
eddieleephd's Avatar
Sounds like it may be a relay starter relay efi relay. I would check all necessary relays including circuit opening relay and move from there to grounds or vise versa.
Old Oct 25, 2009 | 12:41 PM
GavinWhite's Avatar
Thanks for the help
it runs fine now
Old Oct 25, 2009 | 01:24 PM
davo247d's Avatar
what did you do to fix it?
Old Oct 25, 2009 | 11:07 PM
Exclamation
What was it that fixed it?? please always post the fix so future readers know!!!
If you don't post the fix then how will that help the next unfortunate soul???
Glad you got her fixed this is great!!!
Old Oct 26, 2009 | 06:11 AM
BigBallsMcFalls's Avatar
who replaced the starter ? did they do a good job ?
blinking 4wd could be vacuum hose/tank/front actuator
Daenerysdad
Oct 1, 2015 07:33 PM
joeynational
Sep 5, 2015 01:54 PM
86 87 4Runners
Sep 5, 2015 06:02 AM
Ryall
Sep 2, 2015 06:48 AM
86 87 4Runners
Sep 2, 2015 03:54 AM
