aftermarket oil pressure gauge help
i have an aftermarket oil pressure gauge and i took the old sending unit off the block and was going to screw the new fitting into the side of the block and it is a little too big.. has anyone ever had this problem before?
You need an adapter. Toyota engines typically use a British Standard Pipe Taper thread for the oil pressure sending unit.
http://www.autometer.com/cat_accesso...il.aspx?vid=59
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
