Old Feb 9, 2016, 10:52 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Engine Problems by Symptom
Print Wikipost
Help 86 4runner won't start
Old Sep 26, 2009 | 11:30 AM
jscarpino's Avatar
My son and his friends decided to install a new stereo in his 86 4runner 22re 4cyl EFI. After install, the car started. After turning off the car it would not restart. It cranks but won't turn over. I replaced the fuel pump, and filter. We figured out there was no power to the fuel pump. I used the blocking trick with the air flow sensor (blocked it open) the fuel pump turned on and you can now smell gas when we try to start it, still won't turn over though. We have checked and replaced good fuses just in case, also the relays. Any ideas what could be causing the car not to start?
Thanks in advance
Old Jan 8, 2011 | 05:07 PM
redsyota's Avatar
bump...
Old Jan 8, 2011 | 05:49 PM
85gijunk4x4's Avatar
huh????
Old Jan 8, 2011 | 05:51 PM
xxxtreme22r's Avatar
nice bump on a two year old thread, I guess your having the same problem after installing a stereo?
Old Nov 20, 2012 | 11:26 PM
HALIFAX05's Avatar
My 86 4Runner 22R won't start
I have a similar issue except mine is just with installing a battery.
So my truck was running fine except the battery was leaking its fluid so I went to replace it. Went to Walmart and bought an equivalent battery. Put it in the truck and it wouldn't start, and I wasn't getting good connects so I replaced the terminals. After that, still wouldn't crank over. The battery was drained so I got a jump and I think the person who helped put on or removed the cables in the wrong order and perhaps fried something. At that time, I could still hear my fuel pump working and engaging when the key was turned to ACC but not anymore. I got a tow home and I replaced the spark plugs, distributor cap, rotor, plug wires, and today I replaced the MSD SS blaster coil and even the COR fuse and it still won't crank over. I've tried spraying starter fluid down the weber and nothing. All the fuses tested out good. Truck was fine until I went to replace the battery so something must have happened to the electrical along the way, but I'm not even hearing the fuel pump turn on at this point. Any ideas? My email is matthansrecording@yahoo.com. I really need help getting this running ASAP. Mahalo!
Also, what's the "block" trick to get the fuel pump to work?
4cyl 22R .
Old Nov 21, 2012 | 12:18 AM
Terrys87's Avatar
I am not as familiar with the 22r, but you said you may have had the jumper cables crossed when charging the battery. I seen that happen and blow the 80 amp fuse. Is it good.
A 22r has a fuel pump on the passenger side of the block so the jump trick wont work on yours. That is for the EFI motor.
Again not sure of the 22r, but the white lead that goes from the positive cable to the fuse box if a 22r has one, that is the fusible link. It mostly looks like a heavy guage wire. Is it blown?
Old Nov 21, 2012 | 02:56 AM
tampabayota's Avatar
check all grounds
Crazychris1871
Jun 27, 2016 10:38 AM
Sandman
Jul 23, 2015 08:15 PM
aciorba23
Jun 29, 2015 04:18 PM
newzingo
Jun 24, 2015 01:50 PM
Corey
Jun 10, 2002 04:23 AM
