93-98 T100s All T100 trucks
94 t100 axle code
Old Sep 24, 2009 | 04:48 PM
Matt3203's Avatar
94 t100 axle code
my door sticker says A02A r150f
what gear ratio do i have?
Old Sep 24, 2009 | 06:56 PM
Matt3203's Avatar
there no way it could be geared to 3:56
Old Sep 25, 2009 | 12:08 AM
Matt3203's Avatar
this is my door sticker if it helps
Old Sep 25, 2009 | 12:25 AM
vital22re's Avatar
totally a bro
http://www.brian894x4.com/Gearratiosanddiffs.html
scroll down its there.
Old Sep 25, 2009 | 12:29 AM
Matt3203's Avatar
no wonder my truck is so freakin slow, 3.58s with 31s!!!
i need some new gears asap!!! haha
thanks so much vital
Old Sep 25, 2009 | 12:42 AM
vital22re's Avatar
totally a bro
heads up for next time... use the search function here, i typed in gear code and found that.
Old Sep 25, 2009 | 12:44 AM
Matt3203's Avatar
ive been using the search function, but i didnt type in gear code, i typed in axle ratio.
but thanks for your help
Old Sep 25, 2009 | 08:46 AM
Bagger's Avatar
I'm not sure about your door sticker or Brian's site, but my understanding for years now has been that all manual T100's came from the factory with 4.10's and all automatic T100's came with 4.30's.
Ask around on some more active T100 forums and I think you'll hear the same from other longtime owners....
Old Sep 25, 2009 | 06:11 PM
BamZipPow's Avatar
I think the 4 cylinder manual transmission 1994-1998 longbed T-100s came with a lower gear than 4.10...at least that's what www.car-part.com sez.
I'd verify the gear ratio by ErikB's guide...
Old Sep 25, 2009 | 09:55 PM
Matt3203's Avatar
im so confused i dont know which chart to use
one says 3.36 and the other says 3.58???
all i know is it takes my truck like 30 sec to get to 60mph
Old Sep 26, 2009 | 06:32 AM
BamZipPow's Avatar
Use the procedure in the link at EricB's site...
Old Sep 26, 2009 | 12:12 PM
Matt3203's Avatar
i tried useing that but my vin starts with JT***** but it says that my last letter should be a number?
Old Sep 27, 2009 | 09:48 AM
BamZipPow's Avatar
Exclamation
Um...what?
The procedure is as follows...copied from this link that I linked on my first response...
http://home.4x4wire.com/erik/diffs/#ratios
What's my gear ratio? There are several ways figure it out: (top)
* If you think your axle gearing has not been changed since it left the factory, you can read and decode the "axle code" from your vehicle information plate. Off-road.com has some pretty good information how to do this HERE (scroll down to the section titled "Gearing").
* If your differential has been removed so that you can see and count the teeth on the gears, you can divide the number of teeth on the ring gear by the number of teeth on the pinion gear to come up with their ratio. For example, 41/10 gives you a 4.10:1 gear ratio (the most common stock ratio).
* To verify gear ratios w/ the diffs on the vehicle, there is the "spin and count" method:
For "open" diffs:
o Block the tires at one end of the vehicle to keep it from rolling, and then jack up a tire on the other end.
o Place the transmission in neutral and release the parking brake if you are checking the rear diff.
o Spin the tire exactly TWO full revolutions while at the same time counting exactly how many revolutions the driveshaft spins (marking the driveshaft and tires beforehand will make it easier to count revolutions).
o The number of revolutions the driveshaft spins is your gear ratio.
If it spins just over 4 times, then the ratio is probably 4.10; 4-1/3 = 4.30; 4-1/2 = 4.56; just under 5 = 4.88; 5-1/3 = 5.29, etc.
polo451
13
Nov 20, 2016 07:49 PM
rustym
Aug 7, 2015 10:39 AM
Cabell
Jul 24, 2015 12:14 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
jgwerth
Jul 16, 2015 03:23 PM
