Front wheel lean
Old Sep 20, 2009 | 07:59 AM
bain's Avatar
Front wheel lean
What causes your wheels to lean in bad when goin around curves?(top leans in). The front end has been alligned and they dont lean when setting still. Also the front tires like to churp when going around curves..
Old Sep 20, 2009 | 08:20 PM
desertcamper67's Avatar
Caster, which is the front to back tilt of the steering axis is what leans the tire in or out on turns. If your caster is close to spec, then the tilt you see is normal. That is if your steering linkage and other parts are good and not shifting.
The next time you see an older Mercedes sedan turning sharp, notice how much lean is going on there. They run a lot of positive caster.
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
Doug4320
Mar 24, 2018 10:11 PM
1994toyota
Jul 17, 2015 03:03 AM
skoti89
Jul 6, 2015 07:45 PM
