New to Toyotas
Cheapest would be a body lift.
Cheapest half decent way would be shackles
Next cheapest would be add-a-leafs
Theres already a lot of info about lifting a SFA rig do some searches you will learn a lot
Welcome to Yotatech!!!!!!!!!!!!!!!!!
Hmmm, not sure about your truck, but lots of people on here have lifted trucks like that. Try using the search and you'd be surprised what you'd come up with! Enjoy your project!!!!
Oh yeah if you want 36's keep her low. I'm running a tiny lift and planning on 36's soon. The lower the better.
You'l need some wheel spacers in the front and a wide rear axle from an ifs toyota (or spacers in the back too but the axle would cost about the same and its stronger)
Your tire wall will rub on the frame rail when you flex if you dont space the rear and the front will rub on the leafs when you turn.
You could probly shackle lift it another 2 inches, space the wheels out a little and fit em.
I want it lifted, not wide. it aleady has 5.29s in it. i just am lookin for advise for a cheap, efficient lift. i will probably just space the shackles from the frame.
Sep 4, 2015 09:27 AM
