Headers: Downey vs NWOR
Old Oct 13, 2003 | 09:59 AM
scott.475's Avatar
I posted this on 4x4wire also...
I suppose I should just draw the winner from a hat, because I really can't decide. Both companies hate each other and bash each other in their literature, so I am not really that dependant on that. The finish is not so important to me, becasue even if I go with the NWOR offering I think I will have them ceramic coated. I guess my biggest concern is this: the NWOR catalog says "NWOR headers have been designed for maximum clearance between the truck body - "they will not cook your starter motor or burn your carpet" like brand "D" headers." When I look at the pics, it does look like the NWOR headers angle down a little more, while the Downeys seem to be a little straighter, so I can see how the Downeys might run a little closer to the floor pan. Does anybody running the Downeys have any problem with them getting the floor or starter too hot?
Also, anybody running one of the Borla stainless systems on the V6? I called them today and they said it is a 2" system, which seems intriguing. I can get a package deal for a decent price from truckperformance.com. I thin a stainless system would definitely be worth it, esp out here in coastal Washington.
Thanks!
NWOR
Downey
Old Oct 13, 2003 | 02:25 PM
Waterboy's Avatar
I did some research into these two brands a while ago to see which one to go with. I'm still broke with stock exhaust manifold but that is besides the point. I can give you the links if you are interested. Also are you going to go with the cross over pipe or going to make your own? I have a lift to go on sometime soon and was checking the clearence on the front drive shaft. I assume you have a suspension lift since you are running 35's. Downey told me that their cross over pipe won't work with lifted trucks because of the front driveshaft angle difference. I believe NWOR has a cross over pipe that runs behind the t-case. If that makes your decision any easier. Let us know what you go with and how it works out for you. I know I'm interested.
Old Oct 13, 2003 | 04:28 PM
Churnd's Avatar
Stay away from NWOR. No gaskets on a header?? Yeah right.
I have downeys and have had absolutely no problems with them getting too hot, especially since they're ceramic coated. The clearance of the collectors is fine too. I recommend you doing what I did and getting a custom crossover made at a competent exhaust shop to run behind the transfer case. I chose doing that over Downey's crossover and haven't regreted it once.
Old Oct 13, 2003 | 04:37 PM
saigon1965's Avatar
I have been thinking about adding headers also , just to throw a wrench into all this how about the Edelbrocks ?
Old Oct 13, 2003 | 04:52 PM
Churnd's Avatar
They're good if you have the 3.4... and I think this guy has the 3.0.
Old Oct 13, 2003 | 05:04 PM
saigon1965's Avatar
churnd you are correct , newbie mistake , not to hijack this thread but can someone chime in on all the goods and bad of the 3 different system.
Old Oct 13, 2003 | 08:23 PM
sgirt's Avatar
I went with the NWOR header and Y pipe on my 89 v6. It does cross over behind the transfer case. I noticed more power after installing them. I have had mine awhile and they do have gaskets. I've replaced them 3 times. I had them with the Rancho 3.5 inch IFS lift with no problems and now with the Solid Front Axle. They are REALLY close to the front shackle, but shaved the bolt and seem to be fine with no clearance problems of drive shafts etc..
Old Oct 13, 2003 | 09:10 PM
scott.475's Avatar
FWIW, re: blown gaskets, I saw on Trucks that the guy suggested, after installing the headers, run them for a few days, then retorque, run and retorque, run and retorque, and this should compensate for the warping that occurs and help eliminate the blown gasket problem. Has anyone tried this?
Old Oct 13, 2003 | 09:39 PM
PAhydrohead's Avatar
I've had NWOR headers on my 3.0 for almost 5 years without any problems. I'm pretty sure the install instructions tell you to coat the flange of the header with high temp form a gasket. I don't have any ceramic coating on mine and the headers still look good.
Old Oct 13, 2003 | 09:52 PM
ksurfer's Avatar
I took downey over nwor. The biggest reason though is that downey makes the v6 headers with california's strict smog in mind, when I got them about 6 months ago nwor did not have california legal headers. Other than that I think it's a toss up. I have a 4" lift and they fit perfectly. I still haven't had them permantly put on (held on with u bolt brackets)
I think that Downey was also less expensive. It took a long time to get them, so I would check with downey to see if the headers are actually in...and however long they tell you till they'll have them, multiply by two or three and that's when they'll get them and then add a few days for shipping to when you'll have them.
BE Careful of truckperformance.com (TPC) they'll #$% you over. They told me my headers had been sent and lost by UPS before DOWNEY even got them from production. It seemed like maybe they were tryiing to scam UPS or something (at my expense...literally)
The Headers are awesome, no heat issues...my starter is tempermental but thats been that way since I bought my truck..
good luck, headers are great
Old Oct 13, 2003 | 09:55 PM
scott.475's Avatar
Hey Chris (churnd), is your x-over welded to the headers as well, or just bolted on?
Old Oct 13, 2003 | 10:02 PM
midiwall's Avatar
As of last Thursday, Downey's quoting 10/27 as their next shipdate for 3rd gen 3.4L headers. If they hit that date, that'll make a total of 5 weeks from when I ordered them.
Cost wise... TruckPerformance.com sells the ceramics at $341 for the 3.4L auto, including Downey's crossover and collector. $253 for nickel/chrome plated.
Old Oct 14, 2003 | 07:23 AM
Churnd's Avatar
Welded. There's nothing to bolt on to unless you use clamps. I hate clamps because they leak.
Old Oct 14, 2003 | 07:27 AM
oly884's Avatar
Guest
So let's say I get a cross over made. How do I get to the shop? Drive with just the headers on?
Old Oct 14, 2003 | 07:34 AM
Churnd's Avatar
Yep.
I drove to the shop early one saturday morning. I got plenty of looks from those who were out and about at that time.
I was concerned the 02 sensor was going to screw things up by not being connected to the exhaust, but I didn't have that problem for some reason. Then again, I only drove for about 15 miles. Those were the loudest 15 miles that truck has ever seen.
Old Oct 14, 2003 | 08:43 AM
oly884's Avatar
Guest
Sweet. Then this summer, I'm getting headers!
Old Oct 14, 2003 | 11:32 AM
sutlTL's Avatar
Got the Downey headers and complete exhaust system and I have no regrets! I vote for the Downey!
Old Oct 14, 2003 | 03:17 PM
HurleyBoy's Avatar
since were talking about headers here...what would be a good header to buy for my 22 r-e in my 94 pickup?
Old Oct 15, 2003 | 05:13 AM
Churnd's Avatar
LC Engineering.
Old Oct 15, 2003 | 08:52 PM
truckmike26's Avatar
Scott,
I've got that Borla cat-back. I've had it for two years. It's 2 1/4" (it's too cold to run out a check that fact!) but it's been ok. A bit expensive. It comes with one extra long mid-pipe that you'll have to saw down for your wheelbase -- same as mine (not a "bolt-on" for sure). It did come with an O2 block-off for the extra O2 bung on the mid-pipe but nothing else. Plan on trips to the parts store for gaskets and new bolts. I was disappointed Borla didn't include this cheap stuff.
I did notice some more beans and boomier sound around the neighbourhood so it does do the job well.
