3.0 valve cover/cam bearing oil leak
Old Oct 12, 2003 | 11:49 AM
okidoc's Avatar
All right I did the search for rocker cover, vlave cover, oil leak and didn't find anything that wa helpful so I am turning to the yota gods for help.
I have a oil leak on the drivers side valve cover that appears to be coming form the valve cover just above the cam journal. Do these covers warp and then refuse to seal? If so does anyone have a good V/C to sell? I have replaced the gaskets, w/ and without gasket seal.
---or-----
Could the leak be coming from the cam journal somehow?
Old Oct 12, 2003 | 01:02 PM
oly884's Avatar
Guest
I have the same problem on both sides. I just bought some gasket maker, but my valve covers are getting warped so I'm going to replace them next summer when I'm home from school.
Old Oct 13, 2003 | 06:27 AM
okidoc's Avatar
I guess on top of weak HG's and low power 3.0 have leaky valve covers too.
Good luck with the v/c change, btw, how much are new covers, is there an aftermarket dress up alternative??
Old Oct 13, 2003 | 10:47 AM
Babypig's Avatar
If your gonna do this you might as well modify the pvc valve so that you can actually get to it.
Old Oct 15, 2003 | 05:56 AM
okidoc's Avatar
Just for my on info, what else can leak on the backof the 3vze head. Is it possible for it to leak from around the bearing cap?
Old Oct 17, 2003 | 07:42 AM
Firefyter-Emt's Avatar
Yes.. There is a plastic "cup" that is held in place by 2, 6mm bolts and a retaning ring. These are right at the back of the cam. You may be able to even get them off without o\pulling anything off, but it will be a chore. I do have a spare set of covers if you end up needing one, let me know. I don't know about warping covers.. They are very nicely designed. Drop me a PM if you want them.
Old Oct 17, 2003 | 10:37 AM
okidoc's Avatar
I am familiar w/ the end caps and the retaining plate, I should not have to remove the cam journal, right? Just pull the cap from the rear after I take out the clip. What type of clip is it?
Thanks for the offer on the caps I'll let you know. I'm pretty certain that the leak is coming from the top of the journal, between the gasket and the metal of the journal. I'm going to try the v/c first. I was able to slow down the leak a little w/ some gasket maker and a new gasket. I wanted to let the truck sit for at least 10 hours after the repair but I had to move it. The sealant might have helped but was not set up enough to give a solid seal.
bigjstang
Jun 2, 2025 03:56 PM
Eggslinger
Jun 8, 2019 03:32 PM
jakebarrett
Jul 10, 2015 07:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
Gamble_STi
Jul 7, 2015 07:54 PM
