CEL reset: battery vs EFI fuse
Old Sep 1, 2009 | 02:56 PM
DupermanDave's Avatar
So I'm messing around with my engine trying to get rid of a few CEL codes. I've been checking connections and pulling the EFI fuse. No change. I tried a few other things, and then disconnected both terminals on the battery. The CEL went away and there were no more codes. But I have a feeling the light will be back after a few miles of driving.
Whats the difference between resetting the light by pulling the fuse versus removing the battery terminals?
Old Sep 1, 2009 | 04:21 PM
OutlawMike's Avatar
None really, other than you get to keep your radio and clock settings if you pull the fuse versus pulling the battery cables.
Old Sep 1, 2009 | 04:22 PM
yoterr's Avatar
^ thats what i thought
Old Sep 1, 2009 | 04:24 PM
Marc's Avatar
Are you sure you're pulling the right fuse?
Are you taking it out for at least 30 seconds?
Old Sep 1, 2009 | 04:32 PM
874runnersr5's Avatar
ah perfect, ive always wondered.
Old Sep 1, 2009 | 04:56 PM
How can you take out the wrong fuse? The label for the fuse layout is on the top of the box. And I've taken it out for 30 second and as long as 5 minutes.
Old Sep 1, 2009 | 05:05 PM
RMA's Avatar
RMA
same thing with me Pulling the efi fuse didnt work for some reason I had to pull the battery cable that cleared the codes.
Old Sep 2, 2009 | 12:48 PM
well, no CEL light yet after the drive to work
Why would resetting it through the battery change it?
Old Sep 2, 2009 | 01:54 PM
Marc's Avatar
Ok, just checking. Stranger things have happened.
wafoogalla
Nov 2, 2016 11:02 AM
Duppie007
Aug 31, 2015 07:04 AM
hjalti_gto
Aug 24, 2015 11:46 AM
izzmee
Aug 17, 2015 10:20 AM
dpridgeon3
Jul 9, 2015 01:18 PM
