roof rack on 95 4runner
i have a 1995 4runner that i purchased and doesn't have a roof rack. is it possible to install a stock rack onto it without too much fabrication? i have a thule set now but they clamp into the door jambs and if i get a basket then it would cover up the moon roof.
thanks for any help.
uhhh... drag your butt to a junk yard and remove the roof rack from a wreck. I believe it should be a matter of a couple of holes. do some searching on the subject. There are plenty of other threads about it already.
https://www.yotatech.com/forums/f116...f-rack-145998/ ... for one...
https://www.yotatech.com/forums/f116...f-rack-176750/ ... also...
oh, you can also shell out the hundred-and-some-odd-bucks for the Yakima 54" tracks, part #8001127.
match them rails with a load warrior basket. You can keep those over the rear. Again, do some searching - there are PLENTY of threads not only on Yakima Load Warriors, but on any flavor of roof basket for our rigs.
There are 8 bolts, if memory serves, and like Jay said, drill some holes and use nutserts or rivnuts http://www.enfasco.com/frame4.htm (Google them) to fasten it to the roof. You might want to consider some silicone around the nutserts.
BeMiceElf
Oct 10, 2015 09:40 PM
