Torque specs for head bolts and others ASAP
Just finished putting in a new head gasket, started puttingthings back together and realized someone has walked off with my manual. In any event if anyone has a manual/link with the torque specs for headbolts, cam bolts, adn an image of the timing setup it would be GREATLY appreciated.
I can only get so many free rides to work
Thanks
Thanks
Headbolts: 58 ft/lbs
Cam sprocket bolt: 58 ft/lbs
Cam bearing cap bolts: 14 ft/lbs
There's a tightening sequence that needs to be used. It also says to tighten the headbolts in four equal steps of torque.
Good Luck
Good Luck
kgcwb44
Jan 29, 2023 10:02 AM
Sep 4, 2015 09:27 AM
