idiot abs fuse thread, what part do i pull?
does the whole yellow housing come out? or do i open the little plastic door and pull the fuse inside of it out? thanks for helping with this bout of stupidity!
just wanted to be sure before i started pulling on things to hard!
maybe a bit of a back story will spur someone into action!
doing some work on my brakes as they tend to shudder when i'm coming to a stop, i have already replaced all pads calipers and rotors, still had the problem took the rotor's off and had them turned, replaced everything and still having the problem, pulled everything back off and wire brushed the hubs back to the surface , put it all back on, still having the same problem, now my runner sits at a shop getting the rotors turned on the hubs we will see what the issue is i'd like to be able to pull this foose (sic) so i can do a quick check to see if it's the abs system be for i end myself ;-)
the shudder gets worse with speed but is noticeable through all speed ranges.
any thoughts?
(the brakes have been bled so no air in the system)
thanks guys!
any thoughts?
thanks guys!
