General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
idiot abs fuse thread, what part do i pull?
Old Aug 24, 2009 | 12:02 PM
theizzardking's Avatar
does the whole yellow housing come out? or do i open the little plastic door and pull the fuse inside of it out? thanks for helping with this bout of stupidity!
just wanted to be sure before i started pulling on things to hard!
Old Aug 24, 2009 | 02:45 PM
maybe a bit of a back story will spur someone into action!
doing some work on my brakes as they tend to shudder when i'm coming to a stop, i have already replaced all pads calipers and rotors, still had the problem took the rotor's off and had them turned, replaced everything and still having the problem, pulled everything back off and wire brushed the hubs back to the surface , put it all back on, still having the same problem, now my runner sits at a shop getting the rotors turned on the hubs we will see what the issue is i'd like to be able to pull this foose (sic) so i can do a quick check to see if it's the abs system be for i end myself ;-)
the shudder gets worse with speed but is noticeable through all speed ranges.
any thoughts?
(the brakes have been bled so no air in the system)
thanks guys!
5280jo
10
Jul 13, 2015 10:05 PM
hexrain
Jun 27, 2015 06:17 AM
odonekanobe
Jun 26, 2015 02:27 PM
Bru
Jun 23, 2015 06:58 PM
Corey
Jun 25, 2002 11:13 AM
