clutch master cylinder problem!!
ok so i replaced my master cylinder for my clutch and no i have no pressure in it... how do i get pressure built back up cause its not building up and all the bolts are tight so its not leakin fluid.... any help??
I had the same problem on my 86 4Runner a while back, so i just went ahead and replaced the clutch master cylinder and slave cylinder, it was less than 50.00 dollars at Napa so i did both, everything was good after that, so you might need to replace the slave cylinder also.
the1998sr5
15
Jul 14, 2020 08:35 PM
jasonty
41
Dec 23, 2018 01:00 PM
Sep 4, 2015 09:27 AM
1998, 4runner, 95, clutch, cylinder, cylinderoem, googleclutsch, master, napa, pressure, problem, replaced, reservoir, toyota, troubleshoot
