gears 4.88 or 5.29
gears 4.88 or 5.29
ok im not good with this but i have a question. im running a set of 35/14.5/15 with stock 4.11 gears. an i wanted to buy a set of gears.
everyone says to run 5.29 gears. if i run 4.88 gear will it be ok or will it be better to run 5.29's
im new to this. so i don't know to much. i want to know wat u guys have to say.
need some help.
alohaz
need some help.
alohaz
If it is a 5 speed most likely you will want 5.29's or 5.71's I run 5.29's on both my 22re and my 3.0 4runners should have gone to 5.71's on the 3.0 but both run 35 x 12.5 x 15's
If auto 5.29's
IIRC
Oh Ya more info on your truck is always helpful 22r/re/ret , 3.0 , auto , 5 speed , those kinds of things as well as what your most likely to be using it for i.e. rock crawler , mall crawler mudder , you can see where this is going and how it will help people help you out right?
If auto 5.29's
IIRC
XtraCab
Apr 12, 2020 05:25 AM
jerusry
Oct 19, 2015 05:28 PM
FS[GreatLakes]: Wanted: 4.88 front diff, rear 8'' 4.88
jaretstuff
Aug 4, 2015 02:08 PM
