Head Bolt Helicoil
Head Bolt Helicoil
*Sigh* I tightened down 9/10 head bolts in the correct sequence with the correct torque. The very last one keeps spinning. I suppose the threads in the block are degraded.
I assume helicoil is the answer? Never used one, but I suppose I'll figure it out. Just drill it out a little larger, slip the new threads in and be on my way?
More importantly, what size kit should I buy? Thanks for any light yall can shed.
if you decide to heli coil it, dont do it your self....you need a machine that will drill on the perfect line, a machine that will tap on a perfect line so that the hole once repaired is perfectly straight as it was before. and from now on, use arp head bolts, they are worth it....
There really isn't any difficulty in using helicoil. As the bit goes in, the hole itself will right the drill and keep it lined and centered, just drill slow and steady- don't try to ram the bit down the hole. Same with the tap- back it out every little once in a while to keep the threads clean and use some oil on it.
Then after the helicoil is in, as mentioned, replace all the bolts with studs and you won't have to worry about it again.
Unfortunately, the head has to come back off.
kgcwb44
Jan 29, 2023 10:02 AM
Sep 4, 2015 09:27 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
