transfer gear down??
Old Aug 11, 2009 | 11:29 AM
cincy85runner's Avatar
Looking to gear down my transfer Isaw many 4.7:1, looking for 5.0:1. I would do duals but I've heard this is just as good, cheaper, and less work. All comments welcome. thanks
Old Aug 11, 2009 | 11:55 AM
Etype R's Avatar
Stick with the 4.7 gears, they are proven to hold up better. Others do offer larger reductions, but I have heard the 4.7 set is the strongest.
Old Aug 11, 2009 | 12:00 PM
g_cali's Avatar
Edit:
Old Aug 11, 2009 | 12:08 PM
waskillywabbit's Avatar
Anything over 4.7 is overkill/pointless IMO. Twin stick it too.
Old Aug 11, 2009 | 07:52 PM
myyota's Avatar
I have dual Inchworm cases with 5.7 gears, and its a good set up. I don`t have twin sticks though, i really don`t see a need for them.
Old Aug 11, 2009 | 08:15 PM
Hayes's Avatar
twin sticks make turning easier because you can disengage the front axle. Advanced Adapters make the 5.0.
I have no idea about the strength of one over the other, but will .3 reduction yield that much?
I will say this: dual cases with stock gearing gives you more options, dual cases with stock in the front and a 4.7 (for the sake of example) gives you the most options, and a single 4.7 gives you the least amount of options.
This gives you an idea:
Single case - 4.7 low gear
dual case with stock gearing - 2.28, or 5.19
dual case with stock and 4.7 gearing - 2.28, 4.7, 10.7
I think dual cases gives you a 2wd low gearing option (but that I don't know for sure).
If you have the time and money, duals with 4.7 in the rear is the way to go.
Old Aug 11, 2009 | 08:35 PM
dropzone's Avatar
Fossilized
Originally Posted by g_cali
My transfer case was rebuilt and geared down to 9.0:1, i would definately recomend it over dual cases. Cheaper, less work, and just as effective.
9.0 on a single case? Please explain.
I am running the typical 2.28 stock front case and 4.7 in the rear case. Clearancing the transfer case for 4.7's took out a lot of material, not sure that I would want to take out much more.
sure 4.7's in a single case are cheaper than dual cases but you will find yourself wanting the stock 2.28 gear set at times when the distance between obstacles warrant a low range, but 4.7 is too low and high range won't cut it. It can get old waiting for the slow pokes
I am twinsticked like wabbit said. The twin stick is great for disengaging the front axle when the front locker is binding. but with dirty 30's I should have to worry about that now
Having 20 forward and 4 reverse make for great gearing choices.
with 3.9 1st* 2.28*4.7*5.29's 220:1 works pretty good.
Tykiller1994
Aug 10, 2015 07:49 PM
yourrealdad
Jul 29, 2015 11:08 AM
SMOD
Jul 23, 2015 10:29 PM
crashburnoveride
Jul 10, 2015 06:39 AM
