Needed: Vac Diagram for '90 22RE (Cali) AT, AC
Old Aug 6, 2009 | 03:50 PM
qdude79's Avatar
Can't find it. Sticker under the hood is way faded. Any help would be appreciated. Under hood shots of said vehicle would be optimal. Much thanks!!
Old Aug 6, 2009 | 07:38 PM
desertcamper67's Avatar
Show us a picture of the area you are having trouble with and I'll send you a pic of mine. Probably very similar.
Old Aug 7, 2009 | 08:17 AM
qdude79's Avatar
Ok, here's some pics I got this morning.
Note: I unplugged the lines that went from my power steering idle up connection, 'cause it didn't do anything but drop my rpms a bit. I realize the line I routed back from the intake to the idle up valve is wrong, but I didn't have a cap on me at the time. Also, everything else is as I received the vehicle, no changes. One thing I do note is that my AC idle up valve does NOTHING. I've replaced both the valve and the actuator, and verified that the actuator fires. Nothing. Screwing in the plastic adjuster does nothing, but if you pull it out completely it causes the major vac leak and kills the motor. This I do not understand...
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
montanatruck
Feb 26, 2017 07:07 AM
yipyip45
Dec 2, 2015 08:16 PM
RobotMoose
Sep 2, 2015 05:53 AM
tomczaksdiesel
Jul 26, 2015 10:35 PM
