Gasket Sealant
Gasket Sealant
Well, I am happily working through the timing belt, water pump, etc. replacement. Hopefully, I can get the crank pulley off tonight and start getting everything back together this weekend.
I know many of you have done this before; what is the best gasket sealant for the water pump and the water fittings on the one top pulley piece? Any other advice about this job is also most welcome.
I would want to be sure to use sealant if needed. A lot of guys here have done this before and have a lot of handy little tips that let you do a better job than normal repair.
If you can't get to Toyota, use The Right Stuff, TRS, is is sold at Kragen and other autoparts stores.
I always add a very thin film of some type of sealant to my gaskets. Do not add too much, as it will squish out and cause problems, just a thin coat.
Mike
Mike
the grey and black permatex high temp oil resisting silicone has never failed me.
as for the water pump I use only the paper gasket that comes with the pump after a week or a few days that gasket is stuck and sealed to the the pump and timing cover.
I've got a little bottle of some stuff called Indian Head Gasket Shellac. Got it at NAPA to use on paper gaskets for like $10. It's supposed to work on any kind of gasket material(rubber, cork, metal) to help sealing and resistance to chemicals(oil, coolant, fuels). It seems to work real good, though I got by without it for MANY years without any troubles with plain 'ol paper gaskets on they're own. Anyway gotta use it now, I spent the $10 already.
Used it on the water pump, upper water inlet and thermostat housing. Seems to be doing the job.
Make sure the studs for the thermostat housing are in place before you use this stuff on the water pump.
Toyota's new waterpump design doesn't use FIPG or a paper gasket. It comes with a metal/rubber gasket that works perfectly well by itself. At least for the 3.0L and the 3.4L. You didn't specify what engine you're working on.
_Nicco_
Sep 21, 2015 03:06 PM
scottyg486
Jul 19, 2015 05:34 PM
