91' loss of power give me some Ideas!!
Old Jul 15, 2009 | 10:48 AM
Redneck-Superstar's Avatar
Hey yall I have a 91 4x4 Sr5 that has lost power. Engine runs great its only about 3 years old, but now it wont pull a hill for crap. flat ground does pretty good unless you really try to get on it. then its like you are dragging a piano or something. Need some ideas on what could be the problem.
Old Jul 15, 2009 | 10:56 AM
Tofer's Avatar
Sponsor
what size tires? any lift? when was the last time the fuel and air filter were replaced? plugs and wires? engine compression test?
and welcome to yotatech
Old Jul 15, 2009 | 11:01 AM
Everything is stock, Plugs and wires are good. Engine was replaced about 3years ago. Fuel and Air filter are about a month old.
Old Jul 15, 2009 | 01:40 PM
TNRabbit's Avatar
Which engine? What octane fuel are you running? Any mods?
Old Jul 15, 2009 | 02:02 PM
taikowaza's Avatar
You might have a vacuum leak. There are lots of DIY options like using a propane torch and listening for the idle but I recommend a smoke test. One of the Midas shops near me had a smoker diagnostic machine. Turned out I had some minor leaks that were easily fixed with some new hoses. This should also find any exhaust leaks you may have, those can also really hurt your power.
Old Jul 16, 2009 | 03:45 AM
Thanks, that was where I was going to start. I think that is where some of my problems are.
Old Jul 16, 2009 | 05:04 AM
MASON's Avatar
Also check the catalytic converter.
Old Jul 16, 2009 | 01:37 PM
fireman1559's Avatar
if your cat is clogged up it will glow red and your power well........... you wont have any not even on flat ground
Sleaker
Aug 26, 2020 06:03 AM
rushw
Jul 18, 2015 01:46 PM
cars-guy
Jul 11, 2015 07:51 PM
jon.r
Jul 11, 2015 03:34 PM
karbin
Jul 5, 2015 11:37 PM
