Wires Melted by Exhaust need to replace, is 14 gauge wire the right size
Old Jul 11, 2009 | 09:41 AM
simpsons721's Avatar
Red face Wires Melted by Exhaust need to replace, is 14 gauge wire the right size
my wires running near my exhaust melted they are currently electrical taped
to keep them from making my efi 15 amp fuse pop
i bought 14 gauge wire because the guy at home depot said that would be the correct size for a 15 amp fuse it was popping
but when i looked at the 4 wires i need to replace one looks bigger than 14 gauge
please reply so i can figure this out
Old Jul 11, 2009 | 10:01 AM
iamsuperbleeder's Avatar
what are the wires running to, like alternator or what?
Old Jul 11, 2009 | 01:20 PM
no clue
Old Jul 11, 2009 | 01:25 PM
abecedarian's Avatar
hard to say without knowing where the wires run but you cannot go wrong splicing in the same gauge (or larger) wire as what's existing.
Old Jul 11, 2009 | 02:24 PM
Tragic Drive's Avatar
Are they the wires right under the drivers side?
If they are it is prolly your O2 heater wire that was blowing your fuse. It happened to me as well but my wire was rubbing the steering shaft. Is the wire you got stranded or solid core? Your gonna want to use stranded.
Old Jul 11, 2009 | 10:52 PM
RMA's Avatar
RMA
Yea the 4 wires , 2 go to the ecu and check connector, the other two , 1 is power goes to the injectors,ignitor,ignition coil,vsv for egr,vsv for fpu,vsv for AS and IG2 at ignition switch and also check connector the othe wire is ground.
Use the same size wire ,just for peace of mind..
voiddweller
19
May 2, 2016 09:10 PM
5280jo
10
Jul 13, 2015 10:05 PM
OffroadRalph
Jul 2, 2015 07:28 PM
newzingo
Jun 24, 2015 01:50 PM
Bru
Jun 23, 2015 06:58 PM
