Changing 225/75R/15 to 265/70/R16
Old Jun 29, 2009 | 02:23 PM
Steve_97's Avatar
[SIZE="5Hello,
I know you guys get tons of these types of questions, but I have made an effort to search the forums and I have not found my answer.
I have a base model 97 V6 4WD with 15 inch steel rims with the stock 225/75R/15 tires. I want to go to the aluminum rims and 265/70R 16 tires which I have located. They are off an SR5 from 97.
I don’t see there being any clearance issues since was on the SR5 model. Correct?
Questions:
I do see a speedometer and gearing issue as my model had a 3.909 differential. If I don’t change the gears out, am I doing any kid of damage or will I just suffer performance? Are there spedo gear adaptors for the 4 runner to solve the speedometer issue?
Thanks and sorry if this is answered elsewhere.[/SIZE]
Old Jun 29, 2009 | 04:15 PM
KVRunner's Avatar
Fix your text size. That gives me a headache.
Old Jun 29, 2009 | 04:26 PM
eric-the-red's Avatar
I did a swap form 225/75R15 to 265/75R16 on my 01, before the lift, and had no clearance issues. I didn't really notice any performance issues either, even with the original 3.909 gears. The 3.4 has enough torque and power.
As for the speedo I used a Dakota Digital SGI-5. It's easy to install and calibrate.
Old Jun 29, 2009 | 06:08 PM
Steve_97's Avatar
Smile
Thanks for the reply and the suggestion!
Old Jun 30, 2009 | 02:22 AM
jjrgr21's Avatar
i'd just go to 31x10.50's, cheaper, more choices, and easier to find
krimsonone
Sep 13, 2024 09:33 AM
Yotadawgjr
10
Aug 23, 2015 10:51 AM
Dennisx2
Aug 10, 2015 06:48 AM
accuracy
Aug 4, 2015 08:05 PM
Dennisx2
Aug 4, 2015 01:26 PM
