Hard Downshift back into first....
Old Jun 19, 2009 | 04:05 PM
detroitdiesel's Avatar
....just recently.
Had the tran cooler blow last summer. Dreaded strawberry milkshake. Felt weird for two days so i went to The tranny guy who found the proble. He said to rebuild the whole thing to the tune of 3-5K. I flushed the green and the red and replaced the radiator/cooler and it worked like new. Just this past month downshifts were becoming a bit harder so I went to the same guy and he said it was slowly dying. Is there any little adjustment he (or someone else) can make? I have an appointment for fluid and filter on Wednesday. I thought about adding a bottle of a fluid conditioner. Bad idea?
Am I getting the shaft? I know some things... but trannys aint one of them.
What would be a fair market price to rebuild? I live outside Providence.
Thanks, DD
2001 4runner 139K Stock as stock can be.
Old Jun 19, 2009 | 04:22 PM
toyota4x4907's Avatar
Probably would be cheaper to buy a used one and swap it in.
Old Jun 19, 2009 | 11:06 PM
brian2sun's Avatar
I had the same kind of problem with my 4runner. Hard shifts into 1st and I was also getting a nasty studder when it would shift while going up hills. I was a qt. low on atf so I added some. That made a difference for a while, but it came back after a couple weeks. Then I dropped the pan and changed the filter and that did not help. So then I flushed the entire system (torque converter and all) with Amsoil synth atf and no more hard shifts into first and no more studdering.
I figured since you were going to get your pan dropped/filter changed anyway, you might ask them to flush the t.c. too (I used the best synth atf $$ can buy for added assurance). Flushing made all the difference for my truck.
If you're into the DIY thing here's a really good step-by-step writeup on how to do the entire service - check out the flushing procedure at the end, it's really easy to do yourself if you want to save the $$ on that part.
Old Jun 19, 2009 | 11:08 PM
brian2sun's Avatar
http://home.centurytel.net/stevenjac...sh/tranny.html
Old Jun 21, 2009 | 05:08 PM
Thanks for info
I will look into Synthetic super-crap as my friend Hans puts it. Also, The fluid level is high and the tranny guy said "they say it's preferrable/OK to have it high" Is he high?
DD
Old Jun 21, 2009 | 10:03 PM
brian2sun's Avatar
High is o.k., just try not to go over that. Too much can blow seals.
I doubt your trans is on it's death bed. The strawberry milkshake is no good, but it doesn't always kill the tranny and yours has been fine for a year so far.
As far as fluid conditioner, Lucas treatment is good stuff. Just suck or drain a little ATF out 1st since you are already at the high mark.
skoti89
Jul 8, 2015 12:05 AM
bryan34w
Jul 6, 2015 05:53 PM
coryc85
Jul 6, 2015 04:07 AM
elwood73
Jul 5, 2015 07:07 AM
