Nearly new chain making noise.
Old Jun 17, 2009 | 10:05 AM
Kiroshu's Avatar
Once again i post about my engine noise/chain/valves. Ok so today i adjusted the valves and boy she sounds like a quite pretty little sewing machine now. Very quiet valves and performs alil better too. Anywho shes still got chain nosie bad. As i was bumping the engine over with a starter jump wire to adjust valves i could see the chain slinging and pinging. Whats the issue? Me and my dad did the chain job about 40k miles ago if less than that so what? Any ideas. It does not do it all the time. About 50% of the time of engine running.
Old Jun 17, 2009 | 05:55 PM
Kiroshu's Avatar
Nobody? Can too much timing advance cause this?
Old Jun 17, 2009 | 06:01 PM
Matt16's Avatar
The nuts holding the valve cover on should be less than 5ft-lbs- not too much more than finger tight. Too tight and you get a lot of noise.
Old Jun 18, 2009 | 03:25 AM
Kiroshu's Avatar
Its not the valve cover it has nothing to do with it.
Old Jun 18, 2009 | 10:25 AM
Kiroshu's Avatar
Anyone got a idea? I'd like to know where to start. I've drove it the past day or so and the noise only really happens 35-40% of time... chain slapping.... too much timing advance? It does have a slightly high idle of 900-950 and throttle sticks alittle at 1200 sometimes....
Old Jun 18, 2009 | 10:26 AM
Kiroshu's Avatar
Also if anyone has valve chatter i highly recommend adjusting because it helped my engine perform alot better it got rid of random miss fires and a lil stumbling. Plus its not so rough idle. Anywho still lookin for help...
Old Jun 18, 2009 | 03:20 PM
JaredL's Avatar
When I rebuilt my 22RE, I had loud valve chatter because the exhaust was backflowing slightly. It's a long shot...
Old Jun 18, 2009 | 03:54 PM
Flash319's Avatar
Sounds like you have a bad tensioner. They are very delicate. The tensioner uses oil pressure so the chain will bounce around if you are just bumping the engine. Also you can have a rattle at startup because there is no oil pressure.
If you have a chain rattle that comes and goes I would say tensioner.
I did a chain job and 2 weeks later pulled it all apart again because of the tensioner. Ted at engbldr was great and sent me a new one free. I buy all my 22re stuff from him.
Old Jun 24, 2009 | 07:29 PM
Kiroshu's Avatar
hmm i thuoght about the tensioner too. thanks thats def going to be my point of interest. thanks.
Old Jun 24, 2009 | 10:28 PM
Matt16's Avatar
I've spoken with a Toyota mechanic and he said he's never seen a tensioned go wrong. His personal vehicle is a 22RE 4Runner, so I'd be inclined to believe him.
Old Jun 25, 2009 | 08:08 PM
Kiroshu's Avatar
well some people have good luck with certain parts and some don't. But a new chain making noise 40% of the time during driving no matter temp or oil..... i was told by many techs its prolly the tensioner.... but i dunno.
Old Jun 26, 2009 | 07:20 PM
Kiroshu's Avatar
i wonder how such a simple oil pressure tensioner can work sometimes and not... i'm not really in no mood to take off the front of the motor again to fix it.... couple years ago a new timing chain, timing cover, guides, tensioner, water pump, oil pump, and head gasket wear done.... only about 40k miles ago...
Old Jun 26, 2009 | 08:49 PM
Jay351's Avatar
So whats the surefire way for telling the tensioner is bad or not? Without disasesmbly? Got some chain noise right now... not sure whats up
Old Jun 26, 2009 | 08:54 PM
Kiroshu's Avatar
dunno man i'm tripping too. I though of some ideas like thicker oil or slow timing advance which i do plan to try cause my timing is super advanced passed the timing tab itself.
Sep 4, 2015 09:27 AM
thefishguy77
Jul 30, 2015 10:59 AM
razorman8669
Jul 12, 2015 12:13 PM
mlavery85
Jul 12, 2015 10:33 AM
cars-guy
Jul 11, 2015 07:51 PM
