I've got my pinion rotated and cv in the rear for the dual case setup
Old May 28, 2009 | 04:52 PM
fordmgt1's Avatar
Since I'm running dual cases, everyone suggested a cv shaft, so I put the 86 front cv out of my ifs truck. The shaft is 41" long and at an angle or 20 degrees. I set my 3rd up at 18 degrees. I had a couple of questions:
Is this too much of an angle on the 3rd? Will oil still reach the pinion bearing? What is every else running their angle at?
Also, I am using an IFS cv, so I know it does not have as much of an angle as one from a solid axle, but anyone use it in the rear where the angle isn't that great? It looks like mine will be ok.
Thanks for the help.
Old May 28, 2009 | 06:56 PM
TOYOTA 1's Avatar
i would say thats about perfect. and yes it will still oil fine!
not sure about the ifs cv. id just put it in go flex it out and check for binding.
the1998sr5
15
Jul 14, 2020 08:35 PM
oldirtydirt
Feb 23, 2020 09:30 AM
jerusry
Oct 19, 2015 05:28 PM
crashburnoveride
Jul 10, 2015 06:39 AM
toyoda8488
Jul 5, 2015 10:18 PM
