3.0 hg
No, unfortunately to remove the heads to replace the head gaskets you will have to remove the timing belt and and cam pulleys. The camshafts will have to be removed to get to head bolts underneath. If you're going to the trouble to replace head gaskets I highly suggest you replace all components associated with the timing belt as well as getting your heads rebuilt. There are several threads here on HG replacement and have some great information. Good luck,
Bugs
Bugs
You don't need to take the crank pully off for a head gasket change. You leave that entire bottom section of the timing belt untouched. Unless you're also replacing the timing belt?
If you remove the tensioner you should have plenty of slack to slide the belt off the cam gears. Actually even if you remove just the idler on the top that has to come off anyways you should have plenty of slack.
keep in mind, guys, that toyota did a SLIGHT redesign on the 3vze somewhere between 93 and 94... that means that the idler pulley for the timing belt...
so, the newer motors have a bigger beefier tensioner and, IIRC from when i did mine, a larger pulley diameter...
good luck...
good luck...
scott90
Oct 4, 2015 09:21 AM
