No Electrical power
Old May 28, 2009 | 09:18 AM
SnowRunner98's Avatar
No Electrical power
http://i693.photobucket.com/albums/v...8/DSCN0110.jpg
Swapped out my 3.4L, got all down to this can't remember where this went. does this wire go there?
I tried to turn on the truck, no power to NADA! No dash lights, dome, buzzer nothing. Tested battery 12VDC, all connections made... ANYBODY have an idea whats wrong? Clifford alarm, thats what we thought the problem was. talked to the stereo shop, they said I would have lights and stuff just wouldn't start. Kinda in a hurry since this is a DD and my help (brother needs to get back to work) Thanks YT!
Old May 28, 2009 | 11:18 AM
Unhappy No power Help.
going to comb over it, see what happens. can some one pop their hood and look. pretty sure it goes there, hopefully its not a ground.
Old May 28, 2009 | 11:33 AM
vital22re's Avatar
totally a bro
is that the alternator power wire? are you replacing a blown 3.4 or is it replacing a different motor? take a farther back picture so i can see whats around there
Old May 28, 2009 | 11:47 AM
Na, I thought it was but only one wire already goes there. I'll fire up the camera again, that might help figure out what it is. its the fuse panel next to the battery on the drivers side.
Old May 28, 2009 | 12:16 PM
my old 3.4 was making crazy sounds so versus changing out a water pump, timing belt, and not sure what else was making noise. decided to swap out a donor. 97 motor i believe, 98 truck. my wire harness, donor harness was trashed. called some one they said it sounded like it was after the battery. combed the clips, doubling and triple checking them.
Old May 28, 2009 | 12:31 PM
vital22re's Avatar
totally a bro
i think it goes to the battery
Old May 28, 2009 | 12:37 PM
the connector is too small to slide over that, that was my first guess. Testing power at the starter right now.
Old May 28, 2009 | 01:36 PM
Wires crossed. She fired!! WOOO.. it was so stupid it wasn't funny. sounds so much smoother than my old engine. doing final touches, then taking it for a test drive..
coryc85
Sep 9, 2015 06:24 AM
Sidherish
Aug 2, 2015 01:42 PM
v_man
Jul 23, 2015 04:01 PM
luckypig44
Jul 19, 2015 11:25 AM
AaronM
Jul 8, 2015 07:15 PM
