Timing cover too tall
Old May 27, 2009 | 03:50 AM
dptoy94's Avatar
I am just about to finish with a HG and TC replacement. I purchased a used timing cover that was supposed to go on my 94 truck. When I went to install it it was about a 1/4 in taller than mine. My issue is that the person that sold it to me claimed it to be for the 85-95 truck. When I contacted him he told me he was told by someone that it should have fit unless it was a car engine.
From the little I have found on the net it appears that the earlier 20/22r had a slightly taller cover that was used. Can anyone point me in the right direction for something solid that I can link back to this guy. I just want to recover the cash I spent on this cover.
Old May 27, 2009 | 08:22 AM
drew303's Avatar
84 and older 22r blocks are taller.
he sold you a cover for the older style block.
this site has some good info http://ourworld.compuserve.com/homep...pho/eng20R.htm
Old May 27, 2009 | 08:38 AM
DeathCougar's Avatar
It has nothing to do with car Vs Truck engines. It is 84-older vs. 85-newer. You have the 85+ engine, and they sold you an 84-older timing cover. It simply will not work.
Timing covers for the 84-older engines are 11 1/4" tall
Timing covers for the 85-newer engines are 11 1/16" tall
Show them the measurements, and you can also take a pic of your old cover showing the difference.
Old May 27, 2009 | 10:56 AM
abecedarian's Avatar
From- http://www.lcengineering.com/technot...&catid=1&id=49
1975 - 1980 20R Block
Deck Height 11.280"
1981 - 1984 22R Block
Deck Height 11.280"
1985 - 1995 22R-22RE "Laser Block"
Deck Height 11.090"
Also mentioned here: http://www.3rz.net/TechNotes/TechNote48.htm
As you can see, the deck height is shorter on the 85-95 engine blocks and the deck height just happens to coincide with the size of the timing cover.
Old Jun 1, 2009 | 06:22 PM
dptoy94's Avatar
Thanks for the info guys!!! Sorry it took so long to post back, been busy trying to get my money back and get my truck on the road.
icentropy
Sep 16, 2020 02:47 PM
smiley52
Jul 11, 2015 05:16 AM
icentropy
Jul 9, 2015 02:12 PM
