Can I fit 36's?
Can I fit 36's?
Just got a great deal on some dick cepek 36" tires. I got a 3" bl on my 91 p/u... currently running 33's with no rub at all.... what I gotta do to make these fit?
Is that it? All I gotta do is cut the fenders? Sorry to sound dumb... but never tried to run tires this big before...
You may... however...I already have a set of offset deep dish rims...so........ Also...I would just adjust the steering stops to accommodate.... thanks guys... 36's goin on in a few days!!
Hammer the pinch weld in the bottom rear corners of your front wheelwells flat no matter what. How wide are the wheels you'll be running? How wide are the tires? Do you care about your plastic inner fender?
I have 35x12.50 Baja Claws on 10 inch wide wheels. With a 3 inch body lift and 4 inch suspension lift I can still make them rub the pinchweld/inner fender lightly if I try. The biggest factor is the width of your wheels. The wider they are, the more lift you need. Otherwise they'll be hitting that damn bottom rear corner of the fender. Especially with the suspension compressed.
With 15x8s I could probably clear 37x12.50s...I just couldn't afford them.
I'd be more worried about turning those 36's with your 4.10 gears and a 3.0h
I had to trim/grind the pinch welds to clear my 31x10.50 on 15x8 but they would only hit if I got into a real nasty spot. Only took me a couple minutes with a cut-off wheel in a drill(all I had).
I put my 36/14.5/15's on my buddys 4runner and it looked sick. 3inch bl and it looked like a little arctic truck. we didnt have to mod anything but they were on a 8.5 wheel with 4inch bs and the suspension part was tight.
it even fit in the garage
87SR5justin
Sep 29, 2015 02:50 PM
4runnerFireman
Sep 29, 2015 06:24 AM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
anniesball
Sep 5, 2015 08:45 AM
IMO ide get a 4" lift
