Landcruiser 80 Rims Question
Old May 11, 2009 | 11:10 PM
Cmar's Avatar
Hey folks,
I can get my hands on a set of LC80 rims for a good price. Only thing is, they are the ones that use the tapered wheel nuts.
Should I go for these or try to find a set of the ones that use the wheel nut with the washer fitted?
Or does it make any real difference?
Cheers
Old May 12, 2009 | 08:24 AM
TC4RNR's Avatar
it won't work without modification. you need two things.
a.) special lugnuts from wheeler's off-road, it's made by Gorilla
CHROME Acorn E/T Ultra Style Conical Lug Nuts: 1.50ea
http://www.wheelersoffroad.com/tacomablackalloys.htm
b.) enlarge the lug holes on the wheels to 5/8" using a 5/8" drill bit and pair of steady hands holding your drill.
i just did this on my wheels, totally done about 1 hour.
the lug nuts are seated by the shoulder of the lug hole, so it won't be a problem even your drill bit is a bit off center. without the modified lug holes, the regular lugnut can only get 5 wraps around the lugbolt, not enough to get the minimum 8 wraps required to be safely operated.
i noticed you re in ireland, so try to find out if there's any Gorilla dealers over there.
Old May 12, 2009 | 10:42 AM
Cmar's Avatar
So the studs on the 3rd gen are shorter than on an LC80?
What about swapping over the studs?
Old May 12, 2009 | 01:20 PM
TC4RNR's Avatar
probably it will work on yours, because i have thicker Brembo rotors for Tundra brake upgrade.
Old May 12, 2009 | 01:25 PM
DeathCougar's Avatar
Those are 15" aluminum wheels, and IMHO not really much of an upgrade. They are from a 91-92 Landcruiser FJ-80 before they switched to the 16" wheel.
If you currently have 16" rims, the 15" landcruiser rims will not fit.
Old May 12, 2009 | 08:31 PM
TC4RNR's Avatar
those i have are 16".
Old May 12, 2009 | 10:51 PM
Cmar's Avatar
These are the 16 x 8 five spoke ones. They used tapered nuts for the first few years then changed to the nuts with the washer.
Old May 13, 2009 | 05:24 AM
TC4RNR's Avatar
https://www.yotatech.com/forums/f123...safety-179383/
Old May 13, 2009 | 06:26 AM
Cmar's Avatar
Ok, the brakes on mine are not uprated. So shouldn't that equal more thread showing?
I don't want to miss this deal for the rims, but I don't want them mounted in an unsafe manner on my truck.
Old May 13, 2009 | 07:11 AM
TC4RNR's Avatar
i'd say go get them. LC wheels are hard to come by nowdays, even they don't work now, again, it's an easy fix any way.
Old May 14, 2009 | 08:41 PM
TC4RNR's Avatar
these are the exact wheels you're looking for after being modified
16x8, 0 offset
chukarhunt
Dec 8, 2019 11:39 AM
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
4x4-runner
Aug 3, 2015 07:14 PM
Yotoder865
Jul 9, 2015 07:51 PM
