installing transmission and oil temperature gauges in my 89 4runner
Just need to know what Transmission and Oil temperature gauges to get for my 89 Toyota 4runner sr5 v6 auto tranny.
Thanks!
Thanks!
i was considering this:
http://www.maperformance.com/glowshi...ure-gauge.html
Bit it says:
"The sending unit can be mounted directly into the transmission pan. Note: If you have a drain plug in your transmission pan with a 1/8npt fitting, sending unit will work there."
Does my 4Runner have that fitting. When I use a ratchet is 9/16.
I'm not really car smart what-so-ever, just trying to see if my Tranny slipping is at all related with the fluid temperature. And the oil temperature gauge, well why not add it while I'm under the beast.
Bit it says:
Bit it says:
Bit it says:
Virtually all of the bolts, nuts, etc., on your vehicle are metric.
Though your 9/16" ratchet may fit, it only "kinda" fits as the head is metric.
You really should get a set of metric wrenches/sockets, etc.
Fred
Not sure if the ATF cooler lines are hooked up, wouldn't know how to check.
Also, the tranny has 273k
Transmission fluid appears to be darker than usual but still has a red tint.
I would recommend putting the sensor in the cooler line. More info here:https://www.yotatech.com/forums/f2/t...nifold-152844/
This is the gauge I use (12 volt one of course): http://www.egauges.com/vdo_mult3.asp...=EVA_R&Units=E They also sell green bulb covers so they will match our green light instrument clusters.
voiddweller
19
May 2, 2016 09:10 PM
FS[MidWest]: 1995 4Runner 5vz 4x4
vasinvictor
Jan 20, 2016 12:39 PM
FS[PacNorWest]: T100 auto trans/tcase - Bay area, CA
94whiterunner
Sep 22, 2015 07:25 PM
