speedo cable question......
Old Apr 2, 2009 | 09:51 PM
cvc95's Avatar
I own a 90' toyota p'up 2wd cab with a 20r motor on a 79' 4x4 chasis with a 5spd 93' tranny....whew....lol...anyways my gauge cluster in the truck is a mechanical cable type and my tranny is electrical.....so how do i plug the speedocable into my tranny without swapping the tranny?
Old Apr 2, 2009 | 10:03 PM
sinneDBTB's Avatar
get a elec. gauge cluster? you should be able to get a simple after market speedo too
Old Apr 2, 2009 | 10:06 PM
cvc95's Avatar
i purchased a elec. gauge cluster too but i have no idea how to hook it up w/o an ecu?...on my tranny the speed sensor is not hooked up at all.....
Old Apr 2, 2009 | 10:34 PM
sinneDBTB's Avatar
you have no ecu?
maybe the easiest route then would be after market, just ditch the gauge cluster?
Old Apr 2, 2009 | 11:14 PM
cvc95's Avatar
you have no ecu?
yeah i have no ecu because i have a 20r motor...is there anyway i can remove the speedsensor and replace it with a cable adapterplug or something?....if not what kinda of aftermarket ones are out there?do they hook up to my oem speed sensor?
Old Apr 2, 2009 | 11:42 PM
sinneDBTB's Avatar
dont know man you'd have to talk to your parts dealer
Old Apr 2, 2009 | 11:45 PM
cvc95's Avatar
thanks but i tried every dealer on the island of oahu...and got nowhere
Old Apr 2, 2009 | 11:46 PM
cvc95's Avatar
anyone else got any suggestions??
Old Apr 3, 2009 | 10:54 AM
cvc95's Avatar
anybody??
Old Apr 3, 2009 | 11:52 AM
INFINITY's Avatar
so it is a 90 cab with a 90 interior/gauge cluster?
if you have a the ele spreedo setup on the transfer case then just wire the 3 wires up to the back of the 90gauge cluster.
if you have a manual input on the back of your cluster you will need a manual input on the transfercase hole.
they are the same hole on the digital speedo plug and the manual just different adapters on the tcase. if it were me i would go digital on both of them.
Old Apr 3, 2009 | 11:59 AM
muddbogg21's Avatar
i got one i just did almost the same thing i have a 93 yota blew the tranny and put a 90 tranny in and there should be a bolt that you can pull out next to the spot where you mechanical one is put in so to the right of where your mechanical speedo plugs in there is a bolt next to that and its where you can plug the electric one in if thats helps idk it its work with your truck because you have the 20r
Old Apr 3, 2009 | 03:32 PM
cvc95's Avatar
mines is the opposite.....gauge cluster cable----> elec. tranny speed sensor...
Old Apr 3, 2009 | 03:35 PM
cvc95's Avatar
so your saying i can just go to toyota or the junk yard and buy a manual input for my tranny?
Old Apr 6, 2009 | 03:18 PM
cvc95's Avatar
thanks for all your help!!....i got it....woooohooo!!
Old Feb 28, 2012 | 01:51 PM
BlindfoldMemphis's Avatar
Hey, so was it a simple swap? was your speedo correct?
kawazx636
Oct 6, 2021 03:03 PM
Truckwithoutaname
Oct 3, 2015 03:41 PM
charlie_fong
Sep 27, 2015 10:06 PM
rmill05
Sep 27, 2015 01:43 PM
Rcbc92
Sep 26, 2015 03:00 PM
