Help identifying part
Old Apr 2, 2009 | 11:15 AM
Yotas&Jellos's Avatar
On the 3.0, what is the little part between the upper radiator hose and the engine? It has a gasket on it, and two bolts.
I recently had the motor replaced and they didn't use a real gasket, just some Grey goo looking stuff for it, and it leaks a tiny bit. Nothing major. But I was wanting to get a real gasket for it, but am just unsure what it is called.
Thanks!
Old Apr 2, 2009 | 11:33 AM
Bushwhacker's Avatar
Thermostat housing?
Old Apr 2, 2009 | 11:43 AM
Marc's Avatar
I believe it's the Water Outlet.
I think instead of a gasket you use FIPG (form in place gasket) or maybe silicone seal.
Old Apr 2, 2009 | 12:27 PM
DeathCougar's Avatar
From the factory, it should have a very light coating of silicone. If someone makes a gasket, don't use it. You need to use silicone.
Old Apr 2, 2009 | 04:03 PM
Ah yeah, it is the thermostat housing. Thanks guys.
It already has a silicone gasket, or some kind of form in place gasket. Right behind it, on the motor, I see coolant spray, as if it's leaking.
I'm thinking of just re-doing it. Is there a specific type of silicone used?
Thanks
Old Apr 2, 2009 | 04:25 PM
mattaway's Avatar
toyota seal
Old Apr 2, 2009 | 08:57 PM
Its actually not the thermostat housing, its just the upper water outlet
Old Apr 2, 2009 | 10:25 PM
Ah alright.
Where is the thermostat located?
Is there a point to the outlet?
Old Apr 3, 2009 | 02:53 AM
GSGALLANT's Avatar
The thermostat is down where the lower hose connects back to the engine.
You mean other than allowing the water to get from your engine to the radiator, and supporting the upper idler pulley for your timing belt?!? No... other than those two very important functions, it doesn't do a thing.
For the record, I like using "The Right Stuff" gasket maker by Permatex to seal the water outlet. Like mentioned before, FIPG is used there from the factory... there is no "gasket" to buy. If you remove the top half of the outlet, and clean out the old FIPG, you'll see a groove on the top section of the outlet. That's where you put your bead of gasket maker... the whole way around in that groove.
Old Apr 3, 2009 | 03:20 AM
KONASTAR's Avatar
Thanks
High temp RTV black silicone or toyota part # 08826-0080
Mike
Old Apr 4, 2009 | 10:01 AM
hahahah, yeah, I didn't realize a belt was connected, and I figured the water could just flow through? :p
And thanks for the tips on the products! I'm gonna get at it
Old Apr 4, 2009 | 10:35 AM
desert-rat660's Avatar
ive had good luck with ultra grey
88sasturbotoy
Jan 30, 2026 01:57 PM
mskalmus
May 28, 2017 07:51 AM
May 20, 2016 10:27 AM
rushw
Jul 18, 2015 01:46 PM
Fundy Rider
Jul 16, 2015 01:35 AM
