this is a noob question. do you have to prefill a fuel filter when installing.
No, just install the new one.... and then turn the key on for about 20 seconds to prime it, maybe repeat one more time to be safe, and then fire her up. Mine usually only needs about 20 seconds of priming, though
Actually if you want to prime the line, you'll have to jump B+ and FP in the check connector with ignition on - that will bypass the circuit opening relay that powers the pump. The COR doesn't trip until the start signal, so just turning the ignition on doesn't engage the pump.
pyramid
Jul 30, 2015 10:05 AM
