Tire Pressures
Old Sep 11, 2003 | 09:31 PM
Tire Pressures
Ive been reading thru the forums and ive seen alot of posts about tire pressures, the only thing is, i havent seen any that really answer my question. is there any place i can get info on what the optimum tire pressure should be on my 03 taco d.c. prerunner with bf goodrich rugged trail t/a p265/70r16 tires?i have 2 stickers on the inside of the door that give 2 different pressure specs?!?! what pressure should i run?? what the tire max psi is or pick and choose between the 2 stickers?? one sticker says 26 psi for front and back, other says 26 for front and 29 for back. or do i go off of max psi on tire?? any help is appreciated guys....btw....love this forum!!!
Old Sep 11, 2003 | 11:29 PM
Tacoma Dude's Avatar
My door panel sticker says 26 front and 29 back as well as my manual so I go with that.
Old Sep 12, 2003 | 04:18 AM
AznSky's Avatar
you could call bfg.........
Or even just call a local tire place like discount tire. They should be able to tell you by the tire you have, size of it, and the average weight of your truck.
btw I have bfg a/t's and I'm running 35 psi.
edit: but I'm a 4runner so I weigh more
Old Sep 12, 2003 | 05:49 PM
got an email from bfg, it is stated in the bennet garfield tire guide that the pressures for that tire for that truck is 26 psi front and back. thought id post this just in case anyone else was wondering
Old Sep 14, 2003 | 07:42 PM
I don't mean to hijack your post Mav, but I have had a similar question myself.
My 96 Taco had 215-75-14's stock. I went to 31-9.5-15 and have not been sure what psi to run. They are Futura Dakota's and I would not reccomend them, weird tire wear and it's not alignment, or shocks. Anyway the sticker on the inside door says I should run 27 front and 29 rear. Checked with a local tire shop and they said not to run under 35 psi. I currently run 38 front and 41 rear. Tire sidewall gives no min, just max load capacity at 50psi cold.
Do I go with toyota's sticker or the "tire guy's advice"?
Old Sep 14, 2003 | 11:14 PM
Spank's Avatar
Hello, I'll be thread Hijacker number 2. 98 4Runner, stock tire was 265/70R16 Airpresure on vehicle says 29 PSI (if I remember correctly. Now I'm running 285/75R16, and the max tire presure is 65PSI. Sooooo Should I run 29, like it says on the 4Runner on that thing on the driver side, or should I run it higher, not exceeding 65PSI cold?
To answer the first guy, if you are running the size tires that came original with the vehicle, then use the vehicle recommend tire presure (in your manual, or on the driver side, where your door latches to the frame, there's a metal plate with your Vin number, and the tire presure.
Old Sep 15, 2003 | 07:58 AM
amorphous's Avatar
recently.....
I bumped up to 40 psi from 35. It seems to have made a SMALL bump in my mpg (talking like .035!) and now my wife is complaining about the ride being a bit harsh.
Looks like 35 or less would be better for me.
btw, this is on Goodyear MT/S's
~aaron
Old Sep 15, 2003 | 08:13 AM
AznSky's Avatar
ok I can't answer you taco guys' questions, but for spank, with 285's you should be around 35 psi. I believe.
Golden taco, your taco came with 14's???
Old Sep 15, 2003 | 11:38 AM
Spank's Avatar
Cool, thanks Rob!
Old Sep 15, 2003 | 06:22 PM
Fink's Avatar
I'm runnin BFG A/T's (31x10.5) and I have them at 30 all around...and the ride is VERY nice.
Fink
Old Sep 16, 2003 | 02:05 PM
[i]
Golden taco, your taco came with 14's??? [/B]
Yeah It was like a friggin stock lowrider. It didn't hit me till my buddy and his girlfriend got in one day and all she was talking about was being in the lowrider. It was the next day that I decided "the golden taco" was to become "THE GOLDEN TACO"
still under construction:pat:
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Sep 4, 2015 09:27 AM
calderp
Jul 27, 2015 09:58 AM
itzmywife's
Jul 25, 2015 04:55 PM
skoti89
Jul 8, 2015 12:05 AM
