Check Engine light!
Old Sep 9, 2003 | 03:01 PM
twin's Avatar
Question Check Engine light!
I just installed a Gibson side swept cat back exhaust, on my 00 taco Prerunner V6, and now the Check engine light comes on. Can anyone help me with this problem? Thanks in advance!
Old Sep 9, 2003 | 03:06 PM
AverysDad's Avatar
did you reset you ecu already??...............if not i think that may help
Old Sep 10, 2003 | 03:00 PM
twin's Avatar
I un-hooked the battery cable, does that reset the ECU? Or do i need to do something else?
Old Sep 11, 2003 | 01:30 PM
AverysDad's Avatar
how long did you have the battery unhooked for?
Old Sep 11, 2003 | 02:05 PM
twin's Avatar
Five minutes. The light stayed off for twenty minutes and came back on.
Old Sep 11, 2003 | 06:21 PM
AverysDad's Avatar
you might need to find a shop that can read the trouble codes off your rig...........i think some places will do it for free or almost no money (unless you have an OBD II reader , then you can do it for free yourself)
Old Sep 11, 2003 | 10:40 PM
do you have a k&n air filter on it by chance, i had a friend whoi had a k&n air filter and installed a flowmaster exhaust, and his check engine light came on, turned out to be the mass air flow sensor was having a problem with all the air. had to replace the maf, hope this helps.
Old Sep 11, 2003 | 10:41 PM
mas that is (mass airflow sensor) :pat:
Old Sep 12, 2003 | 12:03 PM
Victor's Avatar
Autozone will check the code for free.
Old Sep 14, 2003 | 04:21 PM
twin's Avatar
Thumbs up
Yes i do have a FIPK II, but the light never came on, until i installed the Gibson side swept exhaust. However i found the problem......i did not tighten the clamps from the lead pipe to old exhaust, which was causing a leak. I tighten every bolt on the exhaust, dis connected the battery for five minutes and reconnected it, and so far the light has not come back on.
Thanks for your guys help.
Old Sep 15, 2003 | 11:39 AM
twin's Avatar
Angry
The dang light came back on this morning!I will have to get the code read for sure now......argh!
Old Sep 15, 2003 | 01:58 PM
Cebby's Avatar
O2 Sensor.
Old Sep 17, 2003 | 04:25 PM
twin's Avatar
Yep that is what it is. I have a buddy that used his OBD II scan to find the problem and it 's the sensor right after the catalytic converter. There is no voltage going thru it and it is causing the engine to run lean. It's great to have knowledge of the problem before i take it to the dealership. The warranty should cover it.
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
colinmil
Jul 6, 2015 04:03 PM
