98 Taco Clank from Front Disc
I recently replaced the front pads and calipers. Now, a few months later and all of a sudden, I hear a clanking noise coming from my left front wheel area. I only hear it when rolling backwards (down the driveway) when I lightly tap the brake pedal. Tap-clank, tap-clank, etc. No noise when rolling forward and tapping the pedal. The noise is a "clank" as opposed to a heaver "clunk".
I pulled the wheel and checked the caliper bolts. Pulled the pads and reinserted them. Pad pins tight. Calipers do not leak. Found nothing loose or broken.
Ideas?
Ideas?
>>Did you get the pad anti-rattle springs re-installed correctly after you replaced your pads?
GSGallant,
Yes, if you mean the piece of "tin" that is sprung between the pad pins.
The noise sounds very much like a clank between the ring and pinion in a differential. I tried jerking the jack-shaft around but could not reproduce the clank. Same with the transfer drive shaft - no discernable play. There is a bit of play between the rotor and the wheel but I don't know if this is the cause of the noise. "It wasn't there before".
The U-joints from the transfer case appear okay with no signs of rust and no play that I can detect. They have been lubed religiously. Odd that the clank only occurs when applying the brakes while rolling backwards and not forwards.
GSGallant,
I get more of a clicking from the front when going in reverse, but it only happens the first and sometimes second time I press the brake, after that it no longer clicks. I've attributed it to the pad shifting from a forward position to a reverse position. I don't know if this assumption is true, but I'm hoping it goes away when I replace the pads and rotors (and possibly out of tolerance pad retainer pins) in the future.
I found these posts, which explain my issue (and maybe yours):
https://www.yotatech.com/forums/f2/b...reverse-33115/
https://www.yotatech.com/forums/f2/i...eaking-123800/
Sep 4, 2015 09:27 AM
cgilley
Jul 25, 2015 10:55 PM
ripp96
Jul 25, 2015 02:32 PM
