98 Taco Clank from Front Disc
Old Mar 8, 2009 | 09:37 PM
Pipsisiwah's Avatar
I recently replaced the front pads and calipers. Now, a few months later and all of a sudden, I hear a clanking noise coming from my left front wheel area. I only hear it when rolling backwards (down the driveway) when I lightly tap the brake pedal. Tap-clank, tap-clank, etc. No noise when rolling forward and tapping the pedal. The noise is a "clank" as opposed to a heaver "clunk".
I pulled the wheel and checked the caliper bolts. Pulled the pads and reinserted them. Pad pins tight. Calipers do not leak. Found nothing loose or broken.
Ideas?
Old Mar 10, 2009 | 07:59 AM
atistang's Avatar
maybe check for play in the wheel
could be a control arm bushing, ball joint, wheel bearing.....
Old Mar 10, 2009 | 08:51 AM
GSGALLANT's Avatar
Did you get the pad anti-rattle springs re-installed correctly after you replaced your pads?
Old Mar 10, 2009 | 09:32 AM
Pipsisiwah's Avatar
GSGallant,
Yes, if you mean the piece of "tin" that is sprung between the pad pins.
The noise sounds very much like a clank between the ring and pinion in a differential. I tried jerking the jack-shaft around but could not reproduce the clank. Same with the transfer drive shaft - no discernable play. There is a bit of play between the rotor and the wheel but I don't know if this is the cause of the noise. "It wasn't there before".
The U-joints from the transfer case appear okay with no signs of rust and no play that I can detect. They have been lubed religiously. Odd that the clank only occurs when applying the brakes while rolling backwards and not forwards.
Old Mar 10, 2009 | 10:21 AM
skjos's Avatar
I get more of a clicking from the front when going in reverse, but it only happens the first and sometimes second time I press the brake, after that it no longer clicks. I've attributed it to the pad shifting from a forward position to a reverse position. I don't know if this assumption is true, but I'm hoping it goes away when I replace the pads and rotors (and possibly out of tolerance pad retainer pins) in the future.
I found these posts, which explain my issue (and maybe yours):
https://www.yotatech.com/forums/f2/b...reverse-33115/
https://www.yotatech.com/forums/f2/i...eaking-123800/
Sep 4, 2015 09:27 AM
Up&Down
Aug 11, 2015 10:04 AM
cgilley
Jul 25, 2015 10:55 PM
ripp96
Jul 25, 2015 02:32 PM
razorman8669
Jul 12, 2015 12:13 PM
