wiring Problem. 88 body on 94 chassi
Old Mar 7, 2009 | 07:51 PM
jeffj2689's Avatar
I have a 94 yota with 22re and 5 speed that was rolled over so i started to put a 88 body on that also had a 22re and a 5 speed. i used the ecu and harness off the 94 but the plugs on the cab harness are different. What should i do?? does anyone know what color wire does what on both the years?
Thanks
Old Mar 7, 2009 | 07:56 PM
DeathCougar's Avatar
You are spanning body styles, so you are going to have to find wiring diagrams and start figuring it our yourself
Old Mar 8, 2009 | 12:04 PM
bigtrucknwheels's Avatar
+1
that is going to take a few hours and it is not something that most members are willing to do. I would suggest you get yourself some factory service manuals or wiring diagrams and figure it out for yourself.
good luck! check the stickys at the top of the thread for free FSMs.
Old Mar 8, 2009 | 02:51 PM
ffryno13's Avatar
you should be able to take both harness schematics and figure out which wires correspond to the components just lay your cab harness and engine harnesses out from each each vehicle and look in your manual and just start labeling all your wires. the pins in side the harness clips should be re usable if you take some caution and do get into a hurry
smthwsn357
May 1, 2024 07:28 AM
icentropy
Sep 16, 2020 02:47 PM
Sep 4, 2015 09:27 AM
msane99
Jul 17, 2015 10:13 AM
colinmil
Jul 6, 2015 04:03 PM
