my truck wont run right help!
Old Mar 7, 2009 | 11:35 AM
swaysidelife's Avatar
ok my truck will go into reverse fine and will rev up just fine but when i put it into drive and give it some gas it just dies. can someone tell me whats going on and some help on how to fix it.
Old Mar 7, 2009 | 07:07 PM
byler900f's Avatar
sounds like the torque converter is lugging. Did you try a tranny service/flush? There are alot of good additives out there that may help.
Old Mar 7, 2009 | 08:14 PM
abecedarian's Avatar
torque converter is an interesting hypothesis... but since the engine doesn't change direction when going from 1st to Rev, the torque converter is nearly ruled out- changing direction is handled within the transmission, not the converter.
Does raise some interesting questions though-
... what is the stall speed of the converter?
... are your rear brakes installed properly?
Old Mar 7, 2009 | 08:20 PM
raydouble's Avatar
Any recent maintenance, work done to truck, tranny, brakes etc?
Old Mar 9, 2009 | 08:41 AM
i havent had any major work done. i had my oil change about two weeks ago. and i dont think its the brakes because i would drive in reverse just fine and it would roll forward but when i hit the gas it would just cut out and die.
Old Mar 9, 2009 | 10:09 AM
byler900f's Avatar
ok well the fact that is rolls forward at all... completly elimates my torque converter idea. you say it dies as soon as you give it any throttle. Does it shut straight down or can you peddle it and keep it running? How does the truck run just in park at idle? is it smooth....will it take throttle without a fuss? sorry for all the questions but i am just trying to get a clear picture of the symptoms!
Old Mar 9, 2009 | 03:04 PM
it doesnt shut straight off it kinda spudders out and i can peddle out of it. and i put it in park and reved it up and it was just fine had good throttle response and sounded good.
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
puffin04
Jul 10, 2015 09:17 PM
Badger62811
Jun 26, 2015 09:26 PM
Peteyg39@hotmail.com
Jun 26, 2015 08:15 AM
ibayne
Jun 26, 2015 06:30 AM
