Panhard Bar Measurements
Old Feb 15, 2009 | 07:06 AM
Batsoff's Avatar
Is there a way to get a quick measurement to see if a panhard bar is really necessary after a small lift?
Just installed 906s in the rear of my and I'm interested to know how much my axle has moved in the process (I didn't take any before measurements).
Can I just use a plumbob over the side of the rear fenders and measure to the center of the wheel?
From reading the archives, it seems that most don't think a small lift (2" or so) doesn't require the panhard bar adjustment... but I'm curious to know how much the axle has moved (if any).
Thanks...
-batsoff
2000 SR5 4Runner
Old Feb 15, 2009 | 09:21 AM
SoCalPaul's Avatar
2" on a 2000 is equal to 1" on a 1999. I don't think a new panhard rod is required. Although Toyota changed spring heights several time, I think the panhard rod is the same.
Go ahead, plumb & measure the axle, I'm sure we are all curious. Maybe some others will measure also.
Old Feb 15, 2009 | 09:26 AM
James Dean's Avatar
My 901's on my 93 moved my rear end off center by almost 3/8". Making it 3/4" to one side. This causes dogtracking and can screw with your alignment.
Old Feb 16, 2009 | 04:15 AM
Batsoff's Avatar
Thanks for the feedback fellas... gonna try to get some measurements today. I'll post what I find.
Old Feb 16, 2009 | 10:46 AM
skjos's Avatar
When I had 890's installed the shift was pretty noticable. I switched to 906's and everything looks pretty even - I haven't measured it, just eye-balled it. A panhard bracket or adjustable panhard bar would be a waste of cash for a 906 lift.
Old Feb 21, 2009 | 12:46 PM
Batsoff's Avatar
Just wanted to post my findings after some measurements... trying to find completely level ground is not as easy as it sounds.
I don't think the Panhard bar is necessary either at this point... after several measurements with hanging a plumbob over the side of the rear fender and just measuing to the center of the wheel I get ~3in on each side... it may vary by 1/8" or so, but I'm not gonna worry about it at this point, it was very close.
Just for reference, I'm sitting at 36.25" on the driver side... and just over 36.25" on the passenger side with my 2000 4Runner and the 906s.
-batsoff
Old Feb 21, 2009 | 08:22 PM
skjos's Avatar
Thanks for posting your results. It's good to back-up the eyeball method with quantifiable data.
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
live4soccer7
May 11, 2016 06:52 PM
Obmi
Oct 4, 2015 11:30 AM
voiddweller
Oct 2, 2015 07:47 AM
